This is a question that many ask and each person has their own preference.
My personal opinion is that braid and mono both have their applications and here goes my outlook on both.
Lure fishing - braid is definitely the better option.
Positive's
Negative's
Positives
In 2010 I fished in Barotseland(upper Zambezi) for 7 full month's in that time I landed 72 tigers over 5kgs personally and all of them on braid (30lb berkley power pro).
My biggest on livies was 23lb and my best was a 19lb on a topwater (zaraspook)
Hope this helps
Positive's
- Quicker hook set as it is reaction bite[/*]
- Better feel for the bite as it is direct[/*]
- Better control over fish[/*]
- Better sink rate due to the thin dia[/*]
- Reaction bite with tigers do not require a leader just trace[/*]
- Nice for slicing through salad (grass and weed)[/*]
- Better distance casting (more water time for the lure = more fish)
Negative's
- Braid does not like an abrasive environment rocks, logs etc
[/*] - Your knots have got to be good - know the braid knots and know how to tie them - this is normally where tackle failure occurs.[/*]
- Buying braid that is suited to the application - remember braid that is made for specimen angling is not suitable for tigerfishing - those braids are made for long soft rods and not for hard hooksets (tigers are short stiff rods with vicious hooksets) - my two braids of preference for tigers (Berkley power pro and spider wire)[/*]
- Suffix braid does not work for me.[/*]
- It floats
[/*] - There is good braid and there is cheap braid but there is no "good/cheap braid"
Positives
- Thicker dia means it is less likely to burn you[/*]
- It is not so abrasive on rod guides and reels[/*]
- There is a little more stretch so thereby a little more give[/*]
- can handle abrasive environment[/*]
- better suited to baitfishing - livies or drift baits[/*]
- Better suited to trolling - due to the give[/*]
- Many knots and it is more forgiving if your knots are not so hot
- It has thick dia - not good for castability[/*]
- Not a good product on the reaction bite[/*]
- Be careful of the brand you buy[/*]
- Be sure to cut knots and retie after every big fish or hookup on structure[/*]
Hope this helps
