Tilapia?
Inky Squid
Active member
Hi, I went fishing for grunter in the Wilderness lagoon a few days ago. When i moved higher up the river I saw a lot of HUGE fish. I've been told that thay are Tilapia. Now I wanna know how to catch them - looks like they can put up a hell of a fight on light tackle. I estimate some of those fish 2 - 2.5kgs. Any help with traces/bait would be much appreciated.
Ryan
Buch of earthworms is the easiest way to get them.
FLy - is also very easy if it is to sighted fish - black wolly buggers etc.
Dropshot - Smallest fishlike dropshots you can find - bing minnows
Small crankbaits like Cotton Cordell Big o's, Salmo Hornet no 2's
And Loamsie's old favorite  - Mepps spinner black with hot orange spots
Hope this points you in the right direction
Ryan
HI,
Blue kurper are very tolerant of Salty water and infact in places you will find them alongside saltwater species.
Best is to use a quill float no 10 hook and a few split shot rigged about 20 -40 cm below the float. Make sure you put enough shot on that the float sits jsut above the surface - They are the biggest skelms when it comes to removing bait so you need to finetune your float for best results we used to use porcupine quills and varnish them.
When they pick up the bait the float may lift a few mm and that is all you might see - they are bastards - strike if you have any doubt - they tend to be very spooky if visible you need to get to a point where they cannot see you.
Make sure you put a bunch of worms on the hook. One can also ground bait which is also very successful with the waste from Sorgum beer known as Masess/Maroek/ mawoef but you will be competing with the pig farmers for some of this.
Hope this helps....
cornelius
Hi Ryan,
Howzit?
Maybe you`re talking about a 1/0 hook. Not gonna get much of a bunch of earthworms on a no 10 hook.
Greetings.
Ryan
Hey Louis - nice to see you boet long time.....................
Inky squid - this is the kurper king - and he is in his prime season currently - so fire the Questions away at Oom Louis (Corneleous)
Ryan
Loams - you talk such KAK - comming from a bass fisherman whom buys scented Baits and sprays his artificials(baits) with the likes of garlic that is very rich comming from you....................
Inky Squid
Active member
cornelius or anyone, could you please tell me exactly how to make up the trace when using earthworm? Length, line, etc.....
Ryan
I.S as I said above -20 -40cm from the float.
You can also fish with them with a running sinker -but as soon as they feel the wt of the sinker they tend to drop the bait -but again Louis will be better able to help.
Loams - boet I buy the hooks and then make the artificial from there -currently as I write this I am makeing grass carpfly's for next week.......................:uzi
cornelius
Hi Inky,
I normally tie a short leader appr 15lbs to a 1/0 hook and a swivel 25 to 30 cms above the hook. This is your link to the main line.
Thread your main line through your float and tie to swivel. Tie a sliding stopknot (fig 8 knot with seperate piece of gut)above the float on your main line to adjust the distance between hook and float. Use splitshot on your main line below the float to get your float into the required position and get your bait down quickly.
Determine at what depth the kurpers are biting and adjust your end tackle accordinly. Now go and donner them.
The big ones will move the float laterally and slide it beneath the surface. Small ones will bob the float while they`re stripping the worms off the hook.
@ Ryan - been on leave a bit and didn`t talk too much. Besides didn`t have much worth saying.
Loams
Is that why you're in a mood?? Or is it because you are struggling because your hooks are too big for the wool??
:dban::dban::dban::dban:
Ryan
:ssswim::ssswim::shark:shark:shark:shark:shark:shark:shark:uzi:uzi:uzi:uzi:uzi:uzi:uzi:uzi:uzi:uzi:uzi::gas:::gas:::gas:::gas:::gas:::gas:::gas:::gas::fbash:fbash:fbash:fbash:fbash:fbash:fbash:fbash:fbash:ssswim::ssswim:
cornelius
I S,
Don`t know what the current would be like where u fishing. The sliding weight might be an option if you have a problem with the current and the float. Replace splitshot, float and sliding knot with small sliding weight and voila.
