Tiger gear
Joko
Hi
Which rod and reel can you guys recommend to use for Tiger-fish as well as Large mouth Bass . what are the pro's and con's between a "coffee grinder"and "penn"type reel?
I have a assassin sabre spin 7ft medium heavy and it work pretty good for tiger and bass. A bit stiff for finnesse fishing. I use it with a sienna 2500. Perfect combo. R1000 for the combo. Could also go the medium route. Get a coffie grinder. Easier to fish with and more versitile.
You will not get the perfect rod of both application. As different fishing styles require different type of rods
Limpopoking
I have very little experience in Tiger fishing but I made the switch recently to a baitcaster for bass and I can't see myself ever using a grinder again for this sort of fishing. I bought myself a low profile reel (Shimano Curado) and spent a few days getting to know it. I watched a lot of video tutorials on setting up for casting and changing the settings as you get better. In my opinion, the baitcaster allows you better accuracy and a much higher work rate than a spinning reel. Accuracy in particular, is important when searching for bass. I use braid because I dislike the stretch in mono, so it was a little more difficult to begin with, but I get better with every outing. I intend taking both setups on my next tiger trip.
Joko
Thanks a lot Limpopoking , I like the baitcaster, I do have a Banax Zest baitcaster reel, works fine on the bass , do you think it will perform well on tigers too?
Appreciate your input.
Limpopoking
A mate of mine fishes Tigers up in Zim and he only fishes a baitcasters. Seems to work for him.
On the question of rod... I found that to have the most fun, one needs to have quite a few outfits. I have from med/light all the way up to med/heavy, including a super fast Crucial. I use whatever suits the circumstances and the baits that I'm throwing. I quite often fish weightless plastics. That's when I bring out the med/light. My next tiger attempt will be with my super fast for the best possible chance of a hook set.
Joko
The superfast sounds exciting, thanx for the info. Hope you catch more than the "flu"on your next trip.
