Thinnest fluorocarbon line
Barbelman
I want the thinnest 20lb fluorocarbon line for hooklinks.
What should I look at? I have seen fluorocarbon totally disspearing in water just 8cm deep, while I could still easily see my brown 15lb braid.But the 17lb fluorocarbon I have is too thick for my liking to use as hooklink material
Thanks.
Fishpaste
Fluorocarbon is generally thicker than mono and sinks like a brick. I buy Kingfisher in 10lb for my hooklinks...its about 0.25mm if I recall.
Barbelman
I am not confident enough for 10lb hooklinks. 15lb is the lowest I want to go.
But I might just change my mind one day.
Fishpaste
10lb hooklinks is much stronger than what you may imagine. I have bent hooks open with that same 10lb hooklinks. More important factor for me is the diameter than lb rating. My 2c
Barbelman
Interesting. But yes, my brother had a few bent 0.8 hooks. I fish with a very lightly set brake on my reels so line even if thin will not break. But the problem comes when you encounter snags. I've had bigger fish snap my hooklinks very quickly when getting stuck.
Fishpaste
Best is to fish single hooks if your water has a lot of snags. For me hooklinks has to be thinner/weaker than mainline as if the dreaded happen you only lose the hooklink and not the whole rig. No point fishing a 50lb hooklink and you get snagged up and you have no way of freeing the fish because of too heavy end tackle. Im only saying that as I know you fish with heavy braid from previous posts... ;)
My main line is 8pd and I use 12pd hooklinks/lines. The weekend at rietvlei there was lot of grass in water and we got stuck the whole time. If you walk backwards very slowly, like in give n half meter step back and wait 5sec then another step, then most of time you got loose without mailine breaking. Twice a hooklink broke, but most off the time the hook bended open or even broke.
Barbelman
I suppose you must just use the best quality line as well.
I have 0.20 line that is marketed as 8kg line, but it snaps line nothing!
Beeslek
Thinnest flourocarbon I have used so far is Berkley Vanish,20 lb is 0.40mm.Fishpaste is correct in saying that 10 lb should definitely be strong enough for conventional fishing.Flourocarbon line's main drawback is that it's known for poor knot strength,there are specific knots that should be used to tie flouro.You should be EXTREMELY vigilant of your knots when using flouro,otherwise a heavy hooklink would have seriously reduced breaking strain anyway.
Barbelman
So I got some Berkley Vanish in 12lb. I just want a bit more than 10lb for a bit of confidence:)
When using a knotless knot, it just feels as if the line is coming out at too much of an angle for conventional angling. Is it bad or good?
As I've read that fluorocarbon line can break easily when using the incorrect knots, or tying it incorrectly, I did a few tests, since I am fishing with the lightest line in more than 20 years as well.
I compared it directly to line I thought was good, or at least better. I will not mention its brand, or is it allowed? Anyway, the line is .25mm and is rated at 7.950kg, as opposed to the Vanish that is .30mm and only 5.4kg. Just take a guess which line won? Nope, the other line, despite being rated almost 50% stronger broke first all three times I've tested it.
Seems you should never trust what is printed on the packaging!! I genuinely thought its such great line and very strong for its diameter, but its all, a lie, unless the Berkley Vanish breaks at above its rating as printed on its packaging. Since the 5.4kg Vanish beat the 8kg ''crap'' line I will feel a lot more confident fishing with it. I might even go and get some 10lb Vanish as well.
I am not using the Palomar knot. I use the uni knot for this fluorocarbon. It seems to be a good knot for it. Overhand loop knots, figure 8 knots, and the Palomar knot were tested directly to the uni knot, and the uni knot won all the times.
If you're willing to PAY the price for Super Strong very thin Fluoro then get this stuff...
http://sensationtackle.co.za/bass-line/73-gamma-edge-florocarbon-110m.html?search_query=gamma&results=2
Probably between R1.75-2.75 /m
Barbelman
It looks like very good line, but its still thicker than the Berkley Vanish. .33mm vs .30mm for the 12lb versions. For now I am very happy with the Vanish.
Do the fish really care about the thickness of line if they cannot even see it? Even 20lb fluorocarbon will still be lighter than braid with shot or tungsten putty needed to pin it down to the bottom.
Barbelman
I just want to report back that these Vanish fluorocarbon line is very abrasion resistant. I am quite impressed with it.
Just a last question about using these lines as hooklinks.
Is it easier for fish to eject or feel fluorocarbon hooklinks thsn braid hooklinks? I can't shake this feeling that as fluorocarbon are so stiff as compared to braid, that depending on the angle the fish picks up the bait, that the bait might not fully enter the carps mouth. Just because it resists bending?
