Thin braid to thick leader
Master Diver
Hi All,
I have to tie a 0.21mm braid mainline to a .56 mono leader.
Current knots in the mix are Spyker's and Bob Sand's.
Which one would you go for and are there any other (easy) knots that would be suitable?
MD
Mango
Spyker and bob sand are both great knots and easy to tie once u get usd to them. bob sands maybe a takes abit longer to make.But I pefer it these days where I am casting the knot off the reel.
Are you looking at these due to there castabilty or just to tie on a short mono leader. If just a short leader then A uni will work aswell as 2 back to back 2-3 turn fig 8
Magtellus
I have tried many knots, but for me nothing comes close to the Spyker knot. Its easy to tie and it is bulletproof!
My 2c
Mango
Ok then I will go for the Bob Sands as its design alows for a smoother transition via the guides and the kjnotte nylon profile is also smaller than the spyker
Master Diver
Thanks, Mango.
Do you maybe know of an easy pictoral guide to the Bob Sands? Other than the one on sealine?
Thanks again.
MD
I'll do a new and less complicated post on the knot, having done it so many times now I've got it down and taped.
Tie the Bob Sands in 20 sec. If you go look at the post there is a line art sketch on a knot which is essentially half the Bob Sands (at the end of the threadc), to get the taper and security of the knot just wind back on the initial wraps ie 10 up and 10 down and then through the eye.
Master Diver
Yes Enigma, it's exactly that - very easy (if you know how to) and I think it should be very strong! Will be testing it soon . . . . Thanks for your help on this!
I was thinking of doing a line art sketch, but I'll leave it up to the master/Enigma!
