THE AGONY AND ECSTACY
PH
I have difficulty in paying over R2.00 for an inferior quality, Chinese imported piece of plastic to cover a treble hook.
This project was sparked by a posting by Tyrone Ter Bruggen when he enquired about the availability of properly designed treble hook guards.
In this thread I would like to share my experiences (frustrations and positive results) of a product that might just outperform imported products.
At the outset my design criteria were:
1 It should be as cheap as possible.
2 The treble hook guard should be able to accomodate as many sizes of hooks (and shaft thicknesses) as possible.
3 It must be able to withstand longterm use without "getting worn"
4 It must be easily attached and detached from the hook without dropping off - and clearly visible.
5 It should be shaped in a manner not to snag lines.
6 Not cause damage to lures.
Easier said than done!!
This pic is an indication of the agony to achieve the above goals.
(Thanks to Tye for the encouragement and input during the process of development)
The manufacturing process to follow.
THE AGONY OF DESIGN AND RESEARCH:
PH
Here they are: LOL
Wooden models are made of the mold components
PH
The wooden models are assembled and a silicone mold is cast around the assembly
PH
The polyurethane casting is removed and a bit of flash snipped off.
The pic also shows a single hook guard .
I forgot to mention that a piece of latex rubber is inserted in the mold prior to casting to ensure a firm grip on the hook. These molds are easily reproduced and it takes about 15 mins to produce a casting per mold - including curing time. Now that I'm confident in the performance of the items, I am presently making plenty molds of different sizes.
Is there any point in pursueing single hook guards?
Thanks to Sealiner Tyrone ter Bruggen for the encouragement and comments during the development process.
Andre Laas
Those are looking good! I like the idea a lot. I have made and bought foam hook protectors, but it is a bit fiddly to get on and off. These look like they just slip on and off?
PH
Yes they slip on and "clicks" in place one past the latex rubber strip. A small projection further down inside prevents the hook from falling through. The latex provided adequate resistance to keep the guard secure.
Very very clever! I looked at it and you definitely have a lot more patience than I do! Looks impressive! Now how long will it take you to complete an order of 100 for me?
PH
With the number of molds I have "under construction" presently, I can let you have 100+ in a day. But only next week when the molds are done lol
Tyrone ter bruggen
How did i miss this!?!?!
Guys, the finished product is awesome to say the least.
The first thing that grabbed my attention was the fact that they're strong, probably enough to withstand being stood on.
Secondly, they STAY ON!
And last but not least, economically worth it!
Pierre, all credit to you my friend, it was a pleasure to meet you in person and an honor to know i have such genius mates!!!
P.s. What happened to the beers in the first pic? Was the design work that frustrating???
Lol, Well Done again mate.
