TackleGuard
sharky01
Hi, I have a Penn 500L and Penn Sargus SG6000 and want to protect them after each outing ..... did a search on this forum and came up with TackleGuard spray ...
I wipe my reels down with damp cloth, can I simply spray the entire reel (post says it is line friendly) or should I protect the line ...... or is it better to spray on cloth and wipe down ?
Where in Cpt can I buy this ?
shot !!!
Kumz
in my opinion .. i wud say use it , but spray on a cloth & wipe down ...
you generally dont want any type of residue on yr line ...
my 2c's ...
Mangrove Jack
Hi there,
Fred tuckers has it in stock.
I use it all the time and so do a lot of people I know. I always use it on a new reel before use and again after each use when neccesary.
I know a lot of guys use it and just spray it on all over their line and everywhere. I personally try not to get it on my line but have been out fished by guys who dont!
Spanjard is another good product to use and is basically the same as Tackle Guard. I also use it on my rods and rod guides as often as possible...really does work.
I prefer to remove the spool of the reel and then spray it on...leave it for a while and then wipe off the exess. I then apply it with a cloth to the exposed areas of the spool
Both products are stocked by Fred Tuckers.
MJ
Mike Pike
Spanjaard tackle protector (spray) , one seriously good product ,does the trick on reels, guides, winch, even the rod , no residue, gets rid of moisture and does'nt seem to spoil the line either.
Abaddon
Mangrove Jack wrote:
Hi there,
MJ
This is a superb product and is something I ALWAYS have in my reel servicing arsenal! Like said, I also take every caution not to get any foreign substance on my spools. I go so far as to wash my hands thoroughly after servicing a reel and then handle the spools/lines.. May not be necessary but is just something I do.
Retails for around R35 for a 200ml can. Readily available here in PE from Commercial Marine and a few other tackle dealers..
