Swivel Failure?
khan
Guys i use this simple knot and can tie this in 1 minute, The swivel never breaks but that does not mean that i dont use power swivels, i use these when trying for smaller sharks under 50kg, but for bigger stuff i go with the power swivel just to be safe.
With this knot you can now use a cheaper non return for both eds and non eds.
misguide
skrops wrote:
Okay let me try it this way!
for scratching we mostly use 0.35 - 0.4mm line with a breaking strenght of 8kg using a no.6 barrel swivel with breaking strenght of 15kg. which will break first............one of you knots or the mono:doh
when we fish for eds, most ppl use 0.45mm line which has a breaking strenght of around 14kg, using a no.3 barrel swivel with a breaking strenght of 26kg, where is what gonna break.........one of you knotw or the line:doh
at around R1 a power swivel, maybe it is time to go back to to basics. well for me it is.
For Jason;)
for the big boys, yes you should use power swivels.
Please just say you all agree with me...........or at least come up with a good argument.
Skrops, was just giving u a hard time .....  :fbash
For scratching I have for most of the past used a normal 3-way swivel - however in the last 6 months or so I have gone over to the new power swivel (3 way type).
As for the bigger fish (nunus) the power swivels used all the way.
On my swim traces I am using the bearing type swivels.
I have lost nice fish - at the gaff (100kg plus) where normal barrell type swivels have popped - and yes when I make my traces I do pull to test - to make there are no weak links.
I wouldn't be worried about paying R1 for a swivel - how much did you spend on the rest of your tackle? and your bait? and the petrol to get there? and the time you have put in? even if you lost 30 swivels in a day - how much does that equate to in comparison to your total expenses?
Even if you are using 0.45mm line - surely you are using like a 0.65 -0.75mm leader?
Simen
Khan a question--tying like that ( if I see correct) does it not defeat the object of having a swivel- you can actually tie direct onto the clips eye. I mean there is no swivel action.
misguide
I agree with you Simen.
khan
Simen
that is very true, but as stated, you can now use one slide for eds or non eds.
So no more trying to get power swivel slides
It also take a very short time to make up a trace especially during comb when you have no time and the knot is simple and strong, Its also for the novice that is just starting up.
When stranded for a power swivel non return slide for non eds, now this might help!!!
I use the ball bearing swivels and i have never had any problem with them..but that is only for non eds ..but for all my other aplications i use standard swivels ..but on the other hand i have never caught the size sharks off the bricks like skrops..but all my deap sea applications i only use ball bearing swivels
Kumz
skrops wrote:
Homie wrote:
misguide wrote:
skrops wrote:
thanks guys,
so no need to buy those expensive power swivels for the smaller fish.::S
Do you agree Homie:fbash
:fbash  ........   we dont all fish for smaller fish!   ::S
Hhahahaha Misguide !
Jan, I hear you, but i'll still use the power swivels.
I would not want to risk testing this on a dream fish !!!!
Ja ja...........
I might be older and fatter, but like to stay busy with the little fish while my rod is in the water waiting for the big one.:fbash
What do you guys do............sit and watch the rod::S::S
U think ???? :fbash
skrops
For Jason;)
I hear you, but I just often think that we are over engineering things.
I normally fish with sliding sinker traces(just like them more)so I use two swivels, in moz scratching in the brick I went through a huge amount of traces(swivels), but the cost is not really the argument but more if we REALLY  need power swivels.
I hear what you saying about the shock leader, in effect then the swivel could become the weakes point............hmmmm, good argument:doh. However still think that in the case of fishing for edibles power swivels are a overkill.
Firoze
Hi Guys. I have noticed that the cheaper non return slides on the market have swivels that look like power swivels but in fact are not. They are just made to look like them. I had a slide that when I pulled hard with my hand, the exact same thing happen, the wire broke. Those swivels have brass looking wire and as per the article earlier about the real swivel, the wire is stainless steel and not brass.
Arrie D
A season or two ago we were fishing a comp. at Struisbaai. We fished the Heuningnes river mouth area. Fishing was quite the morning and with the dropping tide I netted some mullet. Had a live bait out on the slide for +- 1.5 hrs when I had the pull. Needing the points and wanting to land the fish badly it was played as gentle as possible. Swam through the river out the other side and just started winning line ( 300m out ) BANG - off. Checked and the barrel swivel broke.
As from that day on I always use power swivels - ed. non ed - does not matter.
Use my normal barrels for catching grunter in the river and as part of my trace for running sinker.
I've had both swivels break on me before and neither were new out of the box.  They were swivesl that were used more than once and they p[opped as a result of corrosion.
This won't happen with high quality power or even barrel swivels as they are made of Stainless steel and hence the price.
Rinsing terminal tackle, if you intend using them again (as with rods and reels) will prevent this.
We tested Kingfisher 1/0, #1 and #2 Barrel swivels up to 70kg deadlift without 1 breakage, didn't go higher because I coudn't pull any harder on the leader I was using.  Something else is going to break before these swivels will break.
This is the result of 2 guys on a 1.5mm leader and a pissed off 78kg Duckbill on the other end and they couldn't break the swivel, stretch it yes, break it no (as a Result I only have slides with S/S Power swivels on for big fish):
