Surf spinning setup
Spoedvraat
Hi guys,
Need some help with a rod and reel matchup for surf spinning. I started out exclusively fishing estuaries, but the "go bigger" bug bit and I want to go into the surf to bump up the size. Problem is I bought a 8ft Daiwa Megaforce rod and a Daiwa 4000 Crossfire reel and some 20lb braid. Problem that I have is that the rod is limiting me to 1oz lures, with which I cannot get the distance that I need. Which rod will you recommend with my current reel or do I have to go all new (rod and reel)? I have thought about purchasing a 10ft Shimano Vengeance as the lure "rating" can go up to 3oz. I might seem brand loyal, but I am not, any recommendations will be appreciated.
Thanks in advance.
OvaR8ed
I have the following two setups that works very well for the price:
1. Sensation Dominator 10ft6 rod with a Penn Sargus 5000 spooled with 20lb Fireline (R1800). The rod is rated 4oz so 2.5oz spoons fly more than 100m easily once you understand the rod's action. The reel is tough enough to crank a ball of seaweed that is stuck to your end tackle up and fly it over the bottom without pumping the rod. Most people think 20lb is too light, but I can tell you, I've been fishing 20lb Fireline for a long time and I even scratch for galjoen in the bricks with it. It can take a lot of punishment while it still allows you to cast a mile.
2. Diawa Exceller 10ft rod with a Diawa Regal 4000 spooled with 20lb Fireline (R1300). This is a cheaper setup, but it will get the job done. The rod is rated 3oz so you can cast the same spoons, but with a slightly slower action. If you push it you'll get 100m with a good spoon. The reel is not the best and it doesn't feel as solid as the Sargus, but I've been punishing one of these for more than two years, occasionally even dunking it under water while wading. If you service it regularly it will give you lots of pleasure.
Hope the info helps, good luck!
