sterkfontein Yellows
kurt
hi guys
i will be visiting Sterkfontein for the first time the week of 5-12 January... any tips on how and where i should target the yellows.
should i take my floattube?
i only have a 8w flyrod so will probably do more spinning ... any advice will be appreciated
waterdog
Take your tube or walk the cliffs looking for fish. Use a 5wt if you can on a long leader throw xmas beetle or grasshopper imitations. Land fly 2m ahead of fish not into the shoal and wait for the take. Do not let them see you. Once spooked move on. Check out sterkfontein take 2 video on youtube...
kurt
thank you for the advice!
i saw on you tube the guys also tie a leader to a popper with a fly on it and then use their spinning gear... might give that a try also...
do you think it is worth fishing with bait at Qwantani ?
waterdog
Popper technique should work. Try get some rebel lures ...the ones that look like grasshoppers. At qwantani fish the the right of pool area with bait. There are also standing trees in the water holding bass. Next to this with bait will produce. From the left of the slip way you will find small cliffs which you can use to look for yellows. We did well on foam hoppers. If nobody around spin in the harbour its got loads of bass but not fishing apparently allowed.
