Tremosso... as far as I understand it the FA is the older version of the Stella. The newer version is the SW...
Nepps wrote this:
The Older FA Series ( The blue and Gold ones ) the 10000FA and the 20000FA spools were interchangeable. I have both 10K and 20K spools for my 10KFA, and 20KFA.
The newer 2008 Stella SW series changed their sizing, with the 10000FA being replaced by the SW18000, which was built with a deeper spool than the original 10KFA to handle heavier braids for popping, along with its higher retrieve ratio than its slower, more jigging orientated twin, the SW20000.
The spools between these two reels, the SW18K and SW20K are interchangeable.
The SW8000 and SW10000 spools are interchangeable, just like the older FA series were between the 6000FA and 8000FA....
At the moment I've got a 20K spool on my 10K FA series.... Its got about 400 or so metres of 100lb Saltiga Boat Braid... perhaps a little less, it actually needs a top up though... I think the spool should hold at least 400 metres of 100lb Saltiga Braid.... I've got 520 metres of YGK Ultra Jigman PE6 ( 86lb Braid ) on my 20K reel and spool.
I'm awaiting a Yumeya 10000 Casting Spool which is an aftermarket Casting spool for the FA series. Yumeya make aftermarket tricked out parts for SHimano, such as extended handles, special spools etc... The casting spool is slightly deeper ( more capacity - approx 30 to 50 metres ) than the original 10KFA spool, and has a narrower casting lip extending casting distance...
The Yumeya should hold approximately 300m of PE6, 240m of PE8 and 190m of PE10....
So your reel should hold about 250 metres of PE6 and 300 metres of PE 5.....
Here is another interesting link where they discuss the differences...
http://www.stripersonline.com/surftalk/showthread.php?t=626832
