Spoons
Made some spoons..
Mould
Resin Plug (in blue) from which the mould is made
First spoon - with prism tape
G
Guest
Guest
Bennie,
Those non painted once, are that white metal? They all look good, and should work well now with the sard around! Whether offshore or on the beach, they will work!
Great work once again!
Cheers,
JUANP wrote:
Bennie,
Cheers,
Correct! they are white metal spoons. The painted ones are lead, 70 grams (jigging version) for water depth upto 30m or 40m with no current. We have been getting Tropical Yellow tail off Durbs, should work a treat on them!
mundis
Hi Bennie sorry to hi jack your thread but you asked me to send some pics of my DIY mould and spinners a while back, but lost my camera overboard and only just replaced it. The advice you gave me to clean up my white metal with candle wax worked a treat.  This is my take on a snake spinner. Took a while to perfect .
qomoyi
thoes are some awsome spoons bennie! :fishni would'nt mind testing a few of them i fish with spoons plenty in the transkei and im heading up to richards bay on the 8th
Excellent, there is more to your mould than meets the eye hey... Looks like some sort of patterning on the back of the spoon. Please share... Weight, length?
mundis
Hi Bennie
The smaller one is 11 cm long and 1.3 Oz and the bigger 14 cm and about 2 Oz little bit light but will be fine from the boat, may add some lead to white metal if i need to increase the weight. Had a couple of small groves put on the back plate to reflect sun but makes pouring a little more tricky. Will give them a bash when there is some tail around and maybe have groves machined away to increase the weight and then just glue some reflective tape to the back. Also did not want to infringe on any copywrights if there are any on the spinner i stole the design from.
mundis wrote:
Hi Bennie
Awesome, perfect weight from a boat! Be sure to send me one or 2 please... ^^.. How about a trade? one of each of yours for 2 of mine??
mundis
Bennie no problem as soon as i pour some more i will pm you for your details. Only have two of each size for myself at the moment. Every time my fishing mates visit  i have given them some to test so need to build up some stock with summer around the corner.
