Spooling reel
Hey buddy..when spooling new line on a reel you dont have to put it on with 30lb's off pressure..lol:)
I have found the best way to be to place the new spool into a bucket off water and run the line thru a telephone directory..if your worried about friction well then a screwdriver thru the spool and get someone to hold the spool with a little resistance...the water helps seat the line a little better and "softens" it up a bit..
Pylstert
I took a long 10mm bolt, a spring and a couple of washers and nuts and tighten the spool up on that and place in a clamp. You can vary the tension by loosening or tightening the nuts. Works pretty well. To remove old line (which I do a lot because of overwinds.....) stick an empty spool in place in a drill and spin the old line off in no time - will post pics later if I get a chance. Cheers Pylstert.
BigBass
Basically agree with Bazooka and Pylstert ...
Soak the spool of line in lukewarm water for a while (15 min) to give it an opportunity to absorb some water and to become nice and supple. I do this with both mono and braid. I know braid does not absorb water, but somehow it also helps to get the braid on nice and tight.
Then take out the spool of line, give a few quick shakes and spool onto the reel as tight as you can putting pressure on the line with your fingers of the hand holding the rod by means of a soft cloth or old cotton handkerchief so the line does not slip or cut your fingers. The reel must be on the rod, drag tight  ...
With spinning reels, place spool of line flat on the ground - the line must come off the spool in the same direction that your reel is laying the line onto the reel - else you twist the line ...
With revolving spool reels, put a pencil or dowel trhough the hole in the spool. Get someone to hold the spool, putting slight pressure on the sides of the spool. Alternatively, hold the pencil/ dowel with your feet, slight pressure of spool between your feet and on a cloth on the floor/ carpet (this can get a bit tricky if there's no-one to help!)
Hah! This sounds VERY useful. Thanks for the tip Pylie! But one question, how do you fix the spool to the drill... photos please....
Pylstert
Hi there,
I hope the picture uploads, there seems to be Gremlins, the page resets. It is really straight forward. To fill your reel, place the spring on the shaft/bolt, it helps to keep a more even tension. You need to lock the two nuts together otherwise they come loose. It helps if you can get two tapered nylon bushes to centre the spool better and add a bit smoother drag. The bigger 0.55mm spools do jump around a bit on the bolt which I usually counter with a piece of hosepipe over the shaft, but that is not ideal.
The pic with the drill is self explanatory, just tighten up, clamp your reel up, turn the drag up slightly to prevent overwind and let go with the drill. Ideally you need a variable speed drill so that you can do it in a controlled fashion. I don't so the thing goes hell for leather, under a minute and your topshot is off. I got this tip from Richard Hills, a Zululand angler.
I have seen such spoolers advertised that have proper centering bushes for the spool, tried to order one no luck.
Pylstert
Pylstert
Thanks, big pleasure I hope no one starts crying or throwing their toys about it :), it seems like drama day on sealine........."Days of our lives" lol!
Leon, you're a flippin' genius bro...  awesome.... I too, have to take line off often.... this is gonna help big time.
Pylstert
Just a pleasure but you should really thank Richard Hills, I think he is still running a tackle shop in Richard's Bay. You are welcome to use it in your new book Reefman! How about you getting a whole lot of co-authors together for the book? Something like Malcolm Meintjies' flyfishing books? Cheers Pylstert
