When spooling a reel with new line it is always a mission to remove the old line, or simply wanting to turn your line around on a reel.
I use a variable speed drilling machine with an adjustable shaft for this. Keep the old empty line spools you have, because 2 is required when wanting to turn round the excisting line.
Simply install the shaft in the drill chuck and place the empty spool between the adjustable cones. set the drill to it's slowest speed. Wind the line onto the empty spool to remove from reel. Remove spool from shaft. When wanting to turn line round -- simply place other empty spool on shaft and wind onto that. Once that is done rewind onto fishing reel.
