G
Guest
Guest
A lot of thimes Specimen Anglers pay atention to their main gear (rods, Reels, Rigs etcetc) and most of the time put a spod rod set-up together that is made out of the "left overs".
I made the same mistake and payed dearly in my first league session. So did some research and kitted myself out with:
- Rod: Fox Spod Rod with 5lb test curve
- Suffex Braid 20lb (0.18mm) - the thinner the better ---> Thinner line improves distance.
- Shimano 6000GTE - cos thats what I had (an option here is to look at the quality of the spool and how easy the line strips from the spool)
This set-up is currently giving me 100+ meters with 7-10 ounces in bait ----> and wait for it - MY SPODS ARE NOT GOING AWOL !!
The braid is also stong enough for you to clip in and not be sacred of breaking off should you cast into the lineclip
