Smooth Cast 300
belindau
Hi Bennie - What lures do you cast with Smooth cast 300. Any pointers in using this stuff. I see you use petroleum jelly as a mold release. Do you use this for all molds or better to buy mold release from AMT. Thanks
If you use silicone moulds, you don't need mould release at all. I use Petroleum Jelly for sealing wood mould boxes when casting silicone moulds. You should use ease release 2000, it's a aerosol spray for no reason other than to prolong the mould but not entirely necessary as nothing (except super glue) sticks to the silicone.
I have used it in the past, but I would generally rather use F16 or F19 because it has a longer pot life allowing for better degassing. I have used Smooth Cast 300 but it cures very quickly.
These are lures I make.
