SM Yellowfish on Fly
Fishpaste
My brother and I decided to go try our luck in the vaalriver this past weekend. Originally we were going to target specimen carp and then just before we left we decided to target yellowfish on fly too. This would be our 2nd trip to the vaalriver and our 1st time targeting yellowfish on fly.
On our arrival it was clear that the carp were spawning crazy and initially thought that we might struggle but nonetheless we caught a few lovely carp with none being below the 5kg mark. All the carp fell for tigernuts.
Right, now to the SM yellows:
Never fished for SM before on fly I literally used the below site as a bible and did everything exactly as they advised and with great success I might add.
http://www.yellowfish.co.za/index.php/38-general-content/articles/61-catching-your-very-first-yellowfish-on-fly
At first it was a bit alien doing very short “casts” and following your strike indicator as it moves down with the current, never quite sure when the indicator submerges whether it is a take or whether it was underwater structure…but then after a short while you get the hang of it and you can distinguish easy enough the real McCoy. One thing is for sure that long casts are unnecessary and actually gives you a disadvantage as it is near impossible to stay in contact with your flies as the current sweeps you fly line downstream causing big loops and you have a lot of slack line in the way when trying to set your hook…
We fished with the Green Grub as our control fly and then the Gold Ribbed Hare’s Ear as our point fly. All fish fell for the Gold Ribbed Hare’s Ear!
We never really had the time to fish intensively as our specimen rods were constantly on our minds and knew that our better halves wouldn’t have the foggiest idea what to do if our alarms went off…
Anyway, there are 2 moments that stands out:
1) Hooked into something and I initially thought I snagged up on a rock or something only to feel that no it is actually moving slowly along the bottom…this fish was so strong that I could not budge it with a 6/7wt and it kept deep all the time moving along at a snail space in the current. My brother and I looked at each other in awe and laughed out loud as it was unbelievable! Anyway, after a good 4 or 5 minute fight the hook pulled… There might be some experts out there that could shed some light but I would have guessed that it could have been a mudfish…which could have been a new species for me!
2) Then right below the weir in the quiet shallow section indicated with the yellow star, I casted at some spawning carp and managed to hook into one for a couple of seconds before it came off – think it was foul hooked. Then casting on the same spot which was literally in front of me, still with the same setup I used for the SM yellows, I saw my strike indicator move 10cm or so. I set the hook and BAM, VAS! Up to the surface came a barble of about 15kg and gave me the biggest hiding of my life!!! it gave a good few short runs in the quiet section but got ***off with me and charged like a raging bull through the streets of Pamplona right into the section where the white water came over the weir (indicated with the red oval in the picture) busting my knuckles as I tried to not let the line tangle… It came to a stop in the main current underneath this “white water” almost as if it dug right into the wall… I literally had to jerk the rod a few times to get it going again! This beast took off and I had a couple of minute of tussle in the rapids before it turned and headed downstream to the bridge where there were loads of dead trees washed up against the bridge (Green line). I applied more pressure and unfortunately the 4.5kg front end parted right at the surgeons loop… Instead of tears out came a few loud swear words followed by me and my brother cracking ourselves with laughter as this was the most exhilarating encounter ever with Mr. Whiskers on the most unlikeliest tackle in the most unlikely of places! All I had to show for it was busted knuckles and the word of my brother.
I figure that it is not about what you catch that makes us return to the water but rather the ones that kicked us in the b*llocks!!! Ever more determined to settle the score on the ones that got away!
Absolutely love the vaal and think I might just go flyfishing there from now on!!!
