SL30SH Bearing kit
Simen
Chey67 wrote:
hi,
where can i get the kit and how much will it cost?
Not sure if Whaler does the kits anymore, but PM him, I am sure he will point you in the right direction.
Just for interest what rod do you have paired with the 30?
JasonF
If you have all the bearings you could go to a bearing supplier in your area and they should be able to supply you with the bearings. Otherwise you can get in contact with Whaler and if he can't help you ask your local tackle store to order you the bearings.
Riaandl
Have a look at this and just take the numbers of the bearings to any decent bearing supplier
Riaandl
Ok the correct bearing numbers:
RH Side Spool - WA676AZ
LH Side Plate - 623ZA
Bottom Drive Shaft - WBCS-92A
Top Drive Shaft - W688AC
eli
hey Chey67 speak to craig neil (sealine name Enigma) at CDS angling, he does reel servicing, repairs and upgrades, he'll sort you out no problem. their number is 0126534499
