SL30 With Penn 14Ft Powerstick
Adi
I an currently using a Daiwa 50HSD with it and it feels a bit unbalanced. casting is Ok but i can get the SL30 for about R850 brand new. Is this a good price and a good reel to suite the powerstick. it has light medium and heavy tips as well. what line should i put on the reel, mainly fish edibles but would like to maybe cast spoons and plugs if i can on this. ANY ADVICE WILL BE GREAT!
surfaMIKE
I think you would be better off with the 50HSD. the sl30 is quite a small reel and IMO would be even more out of balance with that rod. So stick to the 50
line? I would put 10kg (0.42mm) maxima marine green line on the reel if I were you. It should take the full 600m of the spool. Or 0.45mm kingfisher, okuma, 0.425mm XX, any line really... its a personal preference
Def-e-nition
I ave both .
the sl 50 would feel a little bulky On a "Light" rod .But consider the following : The sl is a great reel in my opinion and I would buy it regardless .
The Nice thing though about having 2 Reels is that it's nice to have the , or a , bgger reel to fall back on , as the Sl 30 is a little small . One crows Nest , a Nice one , and you'll only have 1 more chance to fish ....
I use the 30 as often as Possible as I prefer Lighter tackle - but on the Blue marlin rod - it'd simply be too light to work with on there , which is where the toriuum , 50 Or slatist 40 would come in ..
bu tin general - I would just go and buy the thing .
One can never have too many reels ...........!!!!!
Adi
Is R850 a good price for the SL30 and what rod would go well with it. nothin too pricey tho.
surfaMIKE
thats a great price! I would match it to a 12ft loomis shockwave 2-4oz or 12ft sensation shad pro 2-4oz... oh and put .35mm or .40mm line on
rajmank
ive paired my sl30 with a 12 foot elbe waverunner...perfect for scratching..can
also cast pretty far when the need arises
fisheagle
Adi,the sl30 is abit 2small 4 the penn.i would suggest u pair it up with a saltist 40 which is a great reel.the sl30 goes well with lighter rods round 12 to 13 foot,sumthing like a kf stimulator which is an excellent combo 4 edibles
Adi
I got me the 14ft surf with 3 tips and a friend got himself the 13ft spinning rod with 1 tip. he uses a silstar grinder on it. says he doesn't have time for overwinds. i have a silstar grinder as my backup which is not right for that rod but quite fine if i use the heavy tip to stiffen the action up a bit.
