Sinker line snoot vs sinker Oz
gethy
Hi everyone, basically i want to know what is the lowest braking strain i can use for casting 5 and 6oz sinkers without snapping the sinker off.
i used to use the maxima 25lb .45mm line for my snoot and never had a problem, now im trying suffix sfx 25lb .45mm, and found that it snaps very often using 5 and 6oz sinkers. i wanted to if i should use heavier line and do one go about choosing the braking strain of the sinker snoot based on the sinker u casting.
gethy.
reza
the rule of thumb is 0.1 for every ounce so sinker snood for 5oz should be .5 for 6oz .6 etc, unless you fishing rocky area where you want a weaker line to be able to break off if you get stuck
gethy
shot for the tip _seal1_, i went out yesterday and tried a "slightly different" knot using the same line for the sinker snoot, the result was good and i didn't snap off once, but i also wasn't casting really hard because of the wind, maybe Wednesday when the wind drop ill go try again, and just incase ill get .5, and .6 line with. ::tight:
flippy
prefer and trust maxima for all my sinker trace material.. 12kg - 18kg is max ill go for sinker trace.. 12kg for between the rocks and 12kg/ 18kg for surf with less underwater obstructions.. dunno other brands when using as sinker trace but have used in the past and fine if lobbying sinker and not putting anything in the cast really.
also quite a few ways to go about this..
use sinker cord available at shops (rope)
use cup sinkers as bottle shape has sharp inside edges.. heers an example http://www.fishingstore.co.za/cup-fishing-sinkers/
see how this works.. https://www.youtube.com/watch?v=6lasJRsTIGo
lastly use a leader of .50mm minimum that might help less snapping off if you not using a leader already.
The standard conversion was always 10lbs per oz for leader so that should also be more than safe for a sinker snoot
gethy
I am using a piece of rope between the sinker and hook snoot, and yes i am using a leader of .55. all of the break offs were on the sinker snoot so that eliminated the leader as the problem. maybe i should just go back to what worked and get some maxima.
mustbite
Hi there Gethy
I think the problem could be with your knots, I use a .55 hook snoot with a.40 sinker line when among the rocks targeting blacktail .
Targeting fish like cracker I will use a hook snoot of .60+ with my sinker line .55 , I use the bottle sinker as well as the IMP sinker and both work great ,try using perline to make your traces with , I use the improved clinch knot or the fig eight , wet your knots too, as the friction caused from pulling a knot tight can be part of the problem to .
