shimano torium 20
Stout
good day gents, how often do you guys oil your spool bearings? after one session my freespool spinning time decreases quite badly, have to open up after each session, i use reelx corrosion block. thanks
Psy
Stout
You may want try using the oil as well as the grease together. This will effectively keep the oil where it should be. Both are compatible for the bearing.
See mention in post #16 by Grootvis ;
http://www.sealine.co.za/view_topic.php?id=97804&forum_id=10
http://www.corrosionblock.co.za/main.asp?D=%7BA64010CF%2DBA75%2D46CF%2DA194%2D698EA8B94D50%7D&PageType=ProductList&CategoryID=6
These Corrosion Block products can be mailed to your PO Box.
::tight:
Stout
Hi PSY
Thanks for the reply!
I do have both the blue grease and the oil of corrosion block, bought it from old salt 2 years back. I've read the topic, do you suggest i mix the oil and grease or first oiling the bearings and then apply grease? Can i heat up the grease and then mix with the oil?
Psy
I would pull the bearing,clean and apply grease, insert and oil. Cover with a thin film of grease.
Check the bearing..it may be 'out of date'
Splasher
Oiling after each session is hectic.
Unless you are wading or swimming.
Silicon oils stay longer in the bearings when they are getting wet.
Thinner oils wash out quicker than you think.
flippy
all these reels should be shipped to another country.. no wait thats how wars get started :)
reel sounds bone dry if no free spool for even a little amount of time.. like psy said check the bearing and splasher said a thicker oil perhaps
nothing wrong with reel x as cuban uses it and gets great freespool time with a magged reel..perhaps pm him for more inside sneaky info on reel x
Bos-Otter
Stout wrote:
the bearings must be still good, the reel is still brand new guys
There might be your problem? I noticed many of the guys will strip their brand new grinders, clean and re-lubricate their working parts even before they cast the first line.
Whaler
you must use reel x oil on the bearings not the corrosion block, the fiscosity of the grease is probably way to high for the bearings hense them slowing down
This is Reel-X and is not a product of Corrosion Block
I use this on reel bearings and it survives dunking wading and a lot of casting.
Some more information. Do you flush the bearings before oiling them?
The reason I ask is that bearings with old oil residue in will loosen and spin freely with new oil but the contaminants in the old residue will make the oils tacky and sooner than later slow the bearings down again...
Stout
Thanks for the replies,
i use brake cleaner for cleaning the bearings, where can i buy that reel x oil? How do you guys flush out residual solvent left after cleaning? I think that is what disovel the oil that i put in the bearings.
Alan Tani's Blog has probably the most complete thread on bearing maintenance
http://alantani.com/index.php?topic=13.0
http://www.bont.com/news/featurearticles/bearings/clean.htm
https://www.youtube.com/watch?v=wxomaIGjxfs
