Shimano Technium Heavy
Ankie
I bought one Saturday and today I went to test it out. On the 7-9 ounce tip I started with a 6 ounce and went 7, has a nice smooth action.
Then I switched to the 8-10 ounce tip and started with a 7 ounce, first throw smooth second throw bit harder and on the 3rd throw SNAP :fbash tip broke just after the second guide!?!?!
Hopefully Fishing Specialist will sort that out for me tomorrow LOL if not then I'm have to bring out my Gracie Jiu Jitsu skills and test it on those big guys hahaha
subaruseun
3hrs45min later still on...
i find it to be a very reliable casting rod and pulls well..
throws whole yt/bonnie heads with 8 ounce sinker
pity about your snap off, take rod back... let us know the outcome
Ankie
I have no doubt the rod is awesome and can pull decent, great pics there! Gives me a bit more confidence in the ability seeing the pics thanks a lot and will definitely let everyone know the outcome...
Must have been a fault in the tip! So what was the outcome after the long fight :fishn magic carpet?
Dave Batista
The technium heavy is an awesome rod,took mine for a test last night,I used the light tip with a 8oz sinker and Tor 30(0.55mm and 1.2mm)and it throws very far. Then I changed the tip to the heavy and threw a 25cm mullet and 6oz sinker a good distance. This rod has everything you need and is versitile,can cast very far and can pull hard.R1895 with a cloth and a tube. I've yet to throw a 10oz with the Tor 50 on the heavy tip but I'm sure that it will impress me too.
Gonna put some heat shrink over the eva grip soon.Then it will be perfect.
Psy
Thats two rods here on the forum which have snapped!!
Either its workmanship or its handling damage?!
Tough Luck.
Try Blue Marlin Rods!
Stapies
@ Simon, From now on I will call you the elephant! Not because you are big but you dont forget a thing!!! :fbash:fbash:fbash
Yeah this is the second one... I have great confidence in the technium surf elite, but this really strike 2. Same happened on tweede baai when I casted for a mate. Heavy tip with an 8oz sinker, not too hard a cast and snap!!! Same place. Rod got replaced.
I since then bought one and they cast and fight fish well. Not a day of trouble with mine. Great balance and casts a mile. But I still prefer a BM rod above the Techniums...
Dave Batista
Every rod has it's advantages and disadvantages, the techniums advantage is that it is ultra light,casts effortlessly far and is versitile the disadvantages would be that it is more prone to breakage as the walls of the blank are thinner than that of a T53's. Hence the reason for me taking extreme care with mine.
Psy
My Broo, I love shimano products, I have full confidence in them. All my reels are Shimano and one of my rods...that little 110H, jusliak, you know its a good rod...everyone wants one!
I recon the rods that broke had flaws in them, or they were knocked or bumped in travel/transport.
Shimano will never produce a product that will just go to pieces in such a short time.
I saw the workmanship (albeit factory line)on your rod...its good...nothing to fault it.
You say yur buddies rod as well?? yoh then thats 3 brazzo!!
Onse groot Oom daarby die koue water het ene verloor!!
:fishn
Stapies
Psy wrote:
ek lag so lekker, I posted double!
:fishn
hahahahaha ja dis rof!!!! Maar daai stokke is m0er lekker en ek glo dis maar klein foute... Het die ane dag met my technium 'n bronzie van bo 120kg binne 17min op die sand gehad en hy was weer release na 5min op die sand. Getrek dat sy oe traan en geen probleem gehad nie...
Dave Batista
Was impressed with the rod, pairs up well with a Tor 50 and 9oz on the heavy tip. 1st fish on the technium heavy with heavy tip.
Dave Batista
Joker wrote:
Leka fish. Also looking at the Tech Heavy as a 2nd rod...
Get one, you won't be sorry. The heavy tip will pull anything and will cast a mullet and a 7oz as far as you need it to go. The lighter tip is more like a 6-8oz tip than a 7-9oz tip so it can double up as a heavy edible/light shark rod, a 5 or 6oz sinker with a pillie sized bait will go a long way.Very versatile rod.
