shimano Stradic 5000
Beezo
Howsit guys I've been having a problem recently every now and again when I spinning and retrieve my lure the braid seems to wrap around the bottom part of the spool I then have to walk the line out and reel it in again.What is causing that to happen and what can I do to resolve it.Im using a stradic 5000 FJ with 25lb Gosen braid and an Assassin Amia 11ft.Thanks in advance.
Ben REINERS
@Beezo........I see Eugene has already asked you a Q's to assist..........
Also do yourself a favor & check if the number of washers are correct in accordance with the schematics of your reel......the increase/decrease in number can make a difference in the way the braid is spooled when retrieving & possibly bulking up on the bottom more than a even spread of the line on the spool. Just a thought.
Then look at this for interest.......
http://www.stripersonline.com/surftalk/topic/530066-talk-to-me-about-even-line-lay-on-a-spool/
dubliquid
Try not using the automatic bail trip after casting. By manually flipping the bail over you will eliminate the problem.
Psy
I have the same set-up and have not had any issues since installing the braid.
Your issue may stem from your initial spooling/loading of the braid.
search the site for more info regarding spooling braid correctly to the reel, or have a look at this link:
http://www.sealine.co.za/view_topic.php?id=75798&forum_id=10&jump_to=1043586
::tight:
EugeneC
If it happens when you cast you probably have too much braid on the reel. If it's happening on the retrieve there are a number of possible reasons.
I'd start by flipping the bail manually as already advised above and also make sure you lift your rod tip when the lure hits the water so you tighten up the braid before starting your retrieve, this eliminates slack line which causes coiling and is especially important when fishing in strong wind.
If that doesn't fix the problem, re-spool the braid and lastly follow Mr. Refiners' advice. The Stradic is a good little reel and you shouldn't have any trouble fixing this.
Beezo
@Eugene It's happens in the retrieve thing is it doesn't happen all the time.Ive been using the reel for 3 years and it never gave me this problem until recently.
EugeneC
@Beezo, that's quite a strange situation then. I suggest next time it happens take a minute to review if you did anything different or anything unusual happened during the cast / retrieve. That way you can hopefully work backward to figure out what went wrong.
Sorry I can't give you a better answer, maybe some of the other guys on the forum have more experience with the Stradic and may have the solution.
Psy
heres another post/thread worth your perusal
http://www.sealine.co.za/view_topic.php?id=86182&forum_id=1
tight lines mate!
Vandit
Had this happen before, exactly as you describe...
In my situation it was the bail that was bent. When closing the bail the line doesnt slide off onto the line roller and is wound onto the bottom of the spool by the bail wire.
The bail wire was just slightly bent and prevented the bail fom closing completely.
Remove the bail and see whether it recovers when not attached (changes shape significantly when not attached to the reel).
I luckily had an identical reel for reference so I could bend it back to shape.
riekert
I use the Stradic 5000 FJ with 25 lbs Gosen jigging braid. My experiences with intermittent braid coning problems:
a) Get rid of the auto-reset mechanism inside the line roller bearing side of the bail arm! Flick the bail arm over with your fingers instead.
b) Check that the bail arm mechanism is properly lubricated on both sides so that it closes to exactly the right position when you flick it over. Over lubrication, or too thick lubrication, is just as bad as under lubrication and interferes with the ease of closing, in particular on the side of the bail arm not housing the line roller bearing assembly. That side has no spring mechanism to assist in the closing and must be properly lubricated. I do so on a weekly basis.
c) As braid get older with frequent use, I find that it sometimes does not automatically falls snuggly into position into the roller bearing groove after you flick the bail arm over. Instead it remains either to the left or right of the groove at an elevated position (relative to the groove). When this happens it also messes the braid coning up during the retrieve. As a routine I use my fingers to pull the braid into position each time after I flick the bail arm over.
This should solve any intermittent braid coning issues on the Stradic!
