Shimano sidestab 4000re
norco25
Yes, I want to remove it so I can clean the reel as well as adjust the drag, as it is too heavy and not loose enough.
There is no screw on the outside of this drag cover, and it seems as if it is stuck...I am not able to just pull it off.
Any suggestions???
G6
I haven't done one my self yet but I presume u will have to open the reel, under that knob turning thing there should be a clip, attached a pic hope that will helpn the few I have done I had to open the side cover of the reel.
norco25
Thanks,
I appreciate your quick replies.
I beleive that I have to remove the knob first in order to open the reel, and I am battling to pull this knob off. It is not metal so should not have corroded fast.
I do recall having to do this last time I cleaned it, but this time, I just cannot seem to0 be able to remove it,
OvaR8ed
I haven't worked on that reel before, but in my experience, if a part doesn't come of/out easily, don't force it.
Approach it from a different angle or you may find yourself parts shopping sooner than you'd like.
Good luck!
norco25
Actually, I just managed to get it off......there is a 2 pc collar nearest the body of the reel, and if one grips that then the actuall knob unscrews.
I took it apart and think that the problem the which I have is that the inner piece had corroded and the grooves were stripped. The result is that the drag cannot therefore tighten or loosen. It only remains in one tension, which is no good.
I shall either have to get the parts or replace the reel.
It seems from what I have found on the interent that this reelm is not really meant for SALT water (freshwater only) and also have heard that these rear drag reels do not do well in SALT water. We fish here a lot in waders, waist/chest deep on the sandbanks spinning for Bluefish (BIG Elf) and Striped Bass....and our tackle is then getting a lot of saltwater on it. Even though one washes off the reels, they still retain the corrosive element.
Thanks dor all you advice. Much appreciated. (I have moved to this part of the USA about 2 years ago having lived many years in Cape Town)
norco25
norco25
Can anyone tell me where I can source the following part for my SHIMANO Sidestab 4000RE..., Part RD 9452 Pressure Screw ???
Also I require the Schematics Parts Diagram for a Silstar Longcast DR60, where I have a proplem with the Anti Reverse lever. Where can I source this spring?
Any help in sourcing these parts and the diagram would be appreciated.
Thanks,
Norman
For the sidestab enquire from your local Shimano distributor they hold a factory load of spares.
http://www.mikesreelrepair.com/schematics/ for any schematic, if they don't have it then it is no longer available.
Small springs like those you are looking for are easily made with some equivalent diameter AFW wire, should you not be able to get the original part
