Shimano Saragosa 10000 braid capacity
Thctetra
Hi guys,is there any links within this forum regarding regarding braid diameter n line capacity for Saragosa 10000 reel?Using for R n S ....thanks;)
Dries123
http://fish.shimano.com/content/sac-fish/en/home/products/fishing-reels/saltwater-spinning/saragosa-sw.html
Tackle-holic
Just be aware that the #50 Powerpro it is rated to take 360yds of, is not a 50lb braid.
If you opt for something along the lines of Gosen, Grinder Braid in PE4 / 50lb it will take quite a bit more.
Thctetra
Hi..can u elaborate more on the powerpro part?Was thinking what braid brand,diameter n poundage to get to fill the Saragosa 10000 to get around 600mtrs...
Tackle-holic
Gosen PE3 / 42lb
Jbraid 30lb actual BS around 42lb
HMP 40lb
Sufix 832 20lb actual BS around 40lb
Not tried Grinder Braid, but some mates say it is good
Thctetra
Tackle-holic wrote:
Gosen PE3 / 42lb
HMP 40lb
U mean i could get roughly 600mtrs of line on Saragosa 10000 with the braids u mentioned?
A007M21
Spooled my spheros and twinpower 10000 with 350m 30lb whiplash backing and 275m 30lb sufix 832.
625m in total on a 10000
Arno Nel
Hi
I have loaded my Goose with 300m of 50lb whiplash backing and +/-300m of 40lb HMP braid. The HMP could be a bit more than 300m not to certain.
Just watch the way your line is laid on the spool.
Mine is evenly distributed and not form the cone effect to the top or bottom, you have to play around with the spacers that you get with the reel.
Hope this helps
Thctetra
Arno Nel wrote:
Hi
Hope this helps
Thanks;)
