Shimano Corsair CS 400
Arnie909
I need some help please. The anti reverse bearing packed up and stripped the reel last night. Everything else is still in good working condition but this bearing decided that enough is enough. And not when, at the Galjoen Derby she started.
So, my question..... Can you remove the bearing and replace with new one or do you have the replace the whole cover? Google a bit last night but with no luck on the topic.
Bearing code is - F-22070 (if my eyes is not mistaken) Does someone have a number for a Shimano rep in Cape Town?
Arnie909
Reel fixed........::S::S
The side plate and bearing on the old silver CS400 was sold as a single part and not manufactured anymore. Rudy at Somerset Sport helped me out big time with a solution to fix the little reel. After searching most of the Friday for a bearing that will fit but no luck,  no one sells that bearing :Xvvphov The F-228704 (correct code) is a specially made bearing and not sold by any bearing suppliers.
So, we order the Corvalus 400 bearing bracket. This part is sold separately and has the same bearing after we stripped a new reel to have a look. Rudy knocked out the old bearing, this was a mission because the bearing was well corroded. Fitted the new bearing and done.......... Reel works perfectly again!!
I hope this report will help other Corsair owners when the anti reverse bearing pack up.
