Without a doubt my favourite rods for the boat, I have 2 of them, a bit pricy but they are tough. I use Shimano Symetre 4500 FD reels with them and its a good powerful combo. Only problem I have had was the one rods inner eye fell out but was replaced by the supplier, no questions asked.
The subject on overkill gets talked about alot..so that brings me to my Q. Do you pair the 4500FD Shimmie even on the tigers or do you go for a lighter setup..? If so, may I ask what ?
I am considdering the 2pc spinning special tiger and are looking for a reel... always nice having 2 sticks with different bait on them. Ive fished a 7F MH Clarus with a 2500FD Shimmie reel, but let me tell you the fight seems tuff sometimes, bit to lite for me.
The Shimano Symetre is in fact a FD4000 not FD4500. Remove the spool and compare the size of the drag washer to any other reel. It has huge drag washers and in my view the best spinning reel I have ever had. According to Shimano specs it also eliminates line twist. I know we all say it, but the day you hook into that beauty you dream about, you need to have the right equipment for the occasion. It sells for (R800.00 - R900.00) but its the boss.
You right, they are spooled with 13.6kg - 0.35 braid. When you hook into a nice sized fish they dash for cover/structure and on inferior line you have no chance. 600 meters of Suffix Camo Braid costs in the region of R 370.00 but you can do a couple of spinning reels with that.
In December at the coast, I used the same setup for dropshot and it did the job beautifully.
Lovely rod! Kak guides. Strip them off and throw them away. Really not worth taking on a trip that you've paid lots of money for only to have the guides tear up your braid or pop out of the frames. All my mates have had these issues as well as myself with all but one of my 4 Beastmasters. The Trevala ML is a fantastic alternative if you don't mind a one piece.
I'l have to look into it then, thanx. Thats not to bad for 600m of braid.. My calcutta has powerpro 20lb braid.. diameter of less than 2 ! Cant believe where the tecnology are going. Bigg bucks that, wont be able to fill a 4000 reel with such exp braid. 3,5 seem thick though..casting distance ?
