Shimano 110h
campusboy
Hi gents
I just got hold of a old 110h. I just need some info on which reel to pair with it. It will be used as a scratching setup.
Mahi mahi
I fish a Torium 14 on mine and works well for gallies, I have a second 110H that i spin off the boat with paired with a Trinni 16a, casts beautiful and very well balanced. I've also fished with a Speedmaster 20/40 for cracker and although the reel was a bit heavy in my opinion it still did the job!
grootvis
Mine is paired with a Trinidad 16 A for yellowtail spinning, it just is like cream on top of the strawberries.
IWyk
Awesome rods! Bit of overkill for a real scratching rod but at least you will know that you can pull what ever takes the bait with that rod!
I am experimenting with reel combos myself at the moment and will be using the following during December holidays on the south coast.
My son and I will try following.
1 each-Cedros 10(Magged) with 0.7 Awashima big game for Brusher and Rock cod in the bricks.
1 each-15/30, Speedmaster gears, ungrade drag and bearing-still deciding braid or mono
1 Converted to spinning/plugs/poppers-Sargus 8000 and Lethal 80-still looking for the right grinder for this rod not so happy with either of these.(Might look at Raw II or Salina II or Penn Torque-but expensive)
Also have SL20 and SL30 to try if first two options don't work so well.
IWyk
Yip, me too, just hope Craig can get the gears before the holidays. Now just to get the right grinder for the spinning version-I am seriously leaning towards the Raw II 80.
