SHAD HEAD
Howzit Sol,
If it is only the head you want to throw out, use a fairly large hook, 8/0 Kendal, straight through from under the lower lip exiting at where 'nose' would be, about a centimetre from the tip of the mouth.....no cotton to put the fish off.
An alternative would be to do the above but pull the hook through completely on the top of the head and then pin the hook just below the skin with the bend of the hook and the bard sticking out proud towards the cut end of the head. I prefer the first method as it holds up better to throwing and the movemnt in the water.
I have had excellent success with large stumpies at Sezela using just a plain sardine head in this fashion to the amazement of some of my fishing buds.
Hi sol..i personally would slide this bait and i would present it as follows..
Firstly using a bait needle thread your line or steel cable thru the head starting at the mouth and exiting at the belly preferably on the side off just past the gills..attach a treble hook here and pull most off the slack out the line allowing it to stand proud..secure with a toothpick if needed..the top hook should be the weight carrying hook and pulled thru from under the jaw and out the nose,this hook can vary in size from a 5/0 to a 10/0 depending on species being targeted..secure this hook with a snelled knot as explained elsewhere in the forum.. At this point the decision to slide or throw this bait can be made according to the conditions... Tight lines..
