I am always looking for something new, I also have too much kit but then I saw this rod and some reviews.
Has anybody used this rod or blank for light rock and surf?
I need the ultimate 4-5 ounce blank and have not found one that suites me yet.
Craig, I know you are going to read this, can this rod cast 4-5 ounce weights with small bait?
Below is the description on Sensations website.
"In the constant quest to achieve longer casting rods, Sensation has added a top quality 14ft rod to the Pro Series range, designed to meet the needs of serious competitive anglers. The X-Treme Caster is manufactured form HMG 40 Ton Toray carbon to ensure the rod is light and strong. Low rider guides and high grade natural cork grips are all designed to reduce weight and to ensure maximum casting distance. Initial tests show this rod is capable of achieving some serious distance in the right hands, well over 200m. Available in one model only, 14ft 2 piece."
