Hi have a look at this Saragossa 25 000 also serviced for Stefan Germann from free spool angling. The 20 000 and 25 000 share the same base, the spool is the big difference. Have a look at the reel and the build quality. These reels are used for big fish, sharking so they have to be up to the job of pulling big fish. The gearing is made well, the drags strong and carbon fibre, bearings nice large size for sustained load, the pinion gear is carried by 2 bearjngs also. it has an anti reverse roller bearing and double anti reverse dogs. There is no automatic bail engage which I personally prefer not to have as it's just less to break and go wrong. When you look for a reel in a grinder for sharking look for these things and a solid build also. The only downside for me is the right side bearing and main gear bearing housing is not metal but plastic so when guys use this reel like a multiplier on huge fish and not the rod to bully fish this cover tends to stretch a bit, the result is handle play and a bit on the main gear. Other than that a good reel well sealed for water ingress also. You will find more detail on my face book page
