saltist 40H
jethro
hi guys i just got myself the saltist40H and i just opened the box now i was just wondering what are those two small black rubber things in the packet with the rod clamp, thanx
fisheagle
those are break collars.used to slow down the reel so that you dont get alot of overwinds when learning to cast.Slides over the pin you see on your spool when you open the sideplate.
jethro
so if you buy the reel there is no brake collars on because i read of red ones but the ones i got in my box are black so this means i should open the reel to put these collars on is that correct
Richard Ohagan
You should open the reel anyway to give it a lube service, most reels come out and the bearings are dry, so it is always a good idea to lube them before using the reel, that way the bearings and working parts are protected from the word go. At the same time you can put the brake collars on.
