SALTIGA 50 AND 30
old salt
Here are two saliga reels i did for a client who came from another reel techi to me, these reels never ever got the tripple treatment and corrosion, roughness, poor drags were the order of the day. I sonic cleaned them to get years of salt build up and dirt out of the reel seats and thouroughly clean the insides and outside and strip the salt residue of the in and outsides of the reels. These are class reels and deserves the best treatments to keep them in peak performace and protected forward. The spool bearings were replaced and the drags were replaced with carbon fibre drags to restore performance, the clutch lever housing on the 50 was totally worn out, here i machines a custom bush to restore correct function. Have a look at the before and after pictures and see for yourselves what i mean. Enjoy.
old salt
You can check out my page jonathans reel repairs services and upgrades for more detail. Carbontex was added as the drag was extremely poor on both reels. A proper service later they felt like out the box again.
Whaler
hi Old Salt
A friend of mine needs a Star for a Saltiga, his is stripped, could you repair it or do you have a replacement?
i will get him to call you if you can?
Ninja-Nic
Hey Old Salt, sorry if this is a dom question, but how does that sonic cleaning work? It really does clean nicely. Before and after pics are quite impressive.
old salt
Morning ninja
Works by cavitation, you can actually google loads of infirmation, simply it created sonic waves in the water that implode and clean as it does, itslike gently bubble brushing items. Yes it works well gets into the nooks and crannies manual cleaning never really can. Its expensive but for me worth the investment. The strength of the sonic pods are important and frequency they run at. This one i use has adjustabke heat settings also so one can vary that according to the condition if the item being cleaned. Hope this helps._seal1_
old salt
It works really well those hard to reach corroded and salted up areas under the reel seat and between that and the frame gets cleaned really well roller bearings get cleaned inside also. Normal surfaces clean as it squeaky clean. Worth the money spent.
Ninja-Nic
Interesting indeed. I read that you have to keep the item you're cleaning lifted otherwise you dont get the cavitation on surfaces that make contact with the chamber. Is that a serious issue or could you just turn the reel until its cleaned all around?
