Hi There
Most of the times that is 90% i make use of 2 strops
1. sliding sinker i always use a round one on the main line and on the knot a small bead thats on your main line then on the other side of the swiwel i use about 50 cm line with my hook.
no2 a 3 way swiwel one end on my main line then about 10cm long line for your sinker and then on the other end line with your hook.
if you get snagged the thin line with sinker will brake off
Lastly i always fish with high abrasion line as all catfish especcialy the huge ones goes quickly for obstacles such as reeds,trees and any structure under the water and remember the big ones you cant stop and its then that you need high abrasion line
sometimes drift bait and artlure work well but all depent where you fish for the catfish but my believe is doing so you catch the smaller ones like that up to 20 kg i have never caught a bigger one on drift and i struggle with the artlure biggest 5kg but let me tell you artlure is the best i love it it is the best feeling ever when the catfish hits your lure.
good luck
Hennie
