The Jig!
Return
[font="Trebuchet MS, Arial, Helvetica"]
[/font]
Here's another one for your basic bass angling arsenal. The
"Jig 'n Pig" name comes from the fact that many anglers used to (and many still) add a pork trailer to their jig while fishing.
[align=left]The jig consists of four basic components:
1. The Hook
A fairly strong hook is used. As the lure will be used to pitch into timber and brush, a fish that is hooked on a weak hook will have every opportunity to escape if the hook bends as the fish is hauled through this timber. It is also vital to ensure that the hook itself is always kept sharp. There is only one point that will make contact with the fish and you will want to ensure that it is able to penetrate when you strike.[/align]
[align=left]
2. The Brush Guard
The Brush Gaurd prevents the jig from hooking into the brush and trees as it is worked through the cover. A tip here is to spread the guard open a little and this will make for an better hook set when striking. Be careful that you don't spread the brush guard too wide open as you will then have the problem of getting stuck on the cover that you are working. You will read that many people advocate that the brush guard be trimmed to a level where the top of the guard is in line with the tip of the hook. Once again, be careful - this will only lead to more chances of the jig getting stuck on the cover.[/align]
[align=left]
3. The Rattle
The jig really comes into its own when fishing dirty water. Bass tend to stick closer to cover and pitching a jig is one of the most effective fishing tools in these situations. This is where it is vital to ensure that the jig has a decent rattle on it. If you have bought your jig without a rattle, you can attach a rattle to it by simply sliding the rattle over the point and up the shaft of the jig. These rattles are available from most tackle stores and if you are really stuck you will certainly be able to buy one from BassPro or Cabelas. [/align]
[align=left]
4. The Skirt
The final component is the skirt. These are identical to the skirts that are found on spinnerbaits and the colour selection will depend on the water conditions. If you are fishing an area that has crabs / craw in it, match the colour of the skirt to the colour of the bait. An old faithful used by many of the bass pros such as Denny Brauer, and also by many of the local anglers is a plain black or black and blue jig dressed with a black craw with blue pincers or a plain blue trailer. This lure has proved to be deadly in most conditions from murky to crystal clear water. [/align]
[align=left]
Don't be scared to give this lure a try. It is also recognized as a big-fish lure. When you are being pestered by lots of small fish striking your lures, change to a jig and seek out the structure where the lunkers are hiding.[/align]
[align=left]Most of the trailers today are made out of plastic. These don't have the drawback of the pork trailers that will dry out very quickly if left exposed for too long. One word of caution when using plastic trailers - many of these are impregnated with salt and if left on the hook of the jig, will cause the hook to rust extensively. When you are finished fishing for the day, remove the trailer and keep it one side for the next time you go fishing.[/align]
[align=left]Selecting the right trailer for your jig is probably the most important aspect to consider when fishing this lure. I would go so far as to say that even the selection of colour comes second to selecting the optimal trailer to place on the jig. The primary objective when fishing the jig is to place it into the strike zone and to keep it there for as long as possible. There are two alternatives, either downsize the weight and head size of of the jig or increase the size of the trailer.[/align]
[align=left]Water colour is a major factor to take into account: the clearer the water, the smaller the size of the lure that should be used. While fishing stained or murky water, the better option is to increase the size of the lure. Use a 3/8oz jig and attach a large trailer. The jig to the left has a Zoom Super Chunk on as a trailer. The legs on on the Super Chunk have a great action in the water and the bulk on the body provides more resistance during the fall, slowing the bait down as it falls through the strike zone.[/align]
[align=left]While fishing an inter-divisional tournament at Theewaters, Sven Hilland surprised many experienced anglers by adding a full sized Zoom Brushhog to his jig (see photo right). The combination proved devastating as he weighed in a 5 fish bag of 11,05kg and culling a 1,9kg bass in the process. When most anglers were struggling to find a second bass in post-frontal conditions, pitching a bulky bass into the trees proved to be the answer.
[/align]
[align=left]Next time you're struggling to get a decent bite, slow your fishing down and increase your trailer size[/align]
