Removing old anodizing from a reel
Aiden
Hi guys,
I have stripped my Trini 40 of all parts, leaving just the frame, with the old anodizing.
Now Ive read up a bit about removing old anodizing, some say oven cleaner, some say acid. Has anyone done this before? what works without leaving u with half a frame?
Im also planning on re-anodizing the reel soon. Cape anodizing has a minimum charge of R350 for gold anodizing, anyone want their reel gold and share the price?
Thanks in advance.
mark norval
Hi Aiden.
Some advise, I did this myself. The brass and SS parts need to be removed. The side plate were the handle goes has 5pieces that is brass, if removed you wont get it back the same way, the foot piece will have to be removed as well. The acid will dissolve it!!!
The old anodizing they can remove by dipping it in the acid. You can cover above said parts with silicone before anodizing but the colors wont match up 100%.
I did this to my tor30 and still stays bare aluminium, not risking it to loose my reel.
PS: you wont get the anodizing of with liquids, just plain old elbow grease with steel wool or flatting paper.
Aiden
Thanks Mark.
I actually phoned Keith Murison about this issue today. There aren't replacement rivets for the reels, so I would have had to drill them out and put a bolt in their places. Not gonna happen.
Guys at Cape Anodizing recommended that I get it plated as this wont damage any of the metals and they can do the whole thing.
Im so fed up at the moment with the reel, just gonna leave as is. Will the bare aluminium not corrode very easliy?
mark norval
Yep it corrodes, have to clean it after every outing. But I'm happy with my reel looking all crap and things, she still pulls the big fish to the side!!
Aiden
I saw that post. reel looks great. how did you manage to take all the old coating off? Im STRUGGLING in the small areas
mark norval
I had a chroming place polish it for me, the rest I had to do by hand, never came out shiny.
Small file set and steel wool did the trick. to polish aluminium by hand to shine takes allot of work!!
mark norval
Carll wrote:
So you only polished your reel ?
Yes, I will sagest having a clear coat sprayed over it, it will last, I sprayed my reel and fished with it for a while and then stripped it off again. now it stays uncoated, spoke to the guy that does my anodizing and he is going to make my reel look nice again!::S But it is going to cost a pretty penny!
mustbite
Hi guys for ma anodizing would be the best protection you can give to your reel bare alaminuim will corrode over time i wonder if it would be a good idea to spray it with a clear coat the shine will last and it is protected from the elements.
:wfish
