Removing line
RotsRot
Put a screw through a plastic bottle's top, then put screw in drill's chuck like a bit, open bail on reel, tape line to side of bottle, run the drill and strip line off onto bottle...
If you are not going to use it again. Take a very sharp blade and cut the line diagonally and pull all the loose ends up to the top.
This pulls underlying line up and over so you pull of 10-30m at a shot. Goes very quickly.
