reel strong enough?
JasonG
Hi chaps.
I had a fenwick elitetech that a fished for a month or so. it was a 6"7 6-12lb line.
You might think im mad, but as much as i loved the rod and its eyes... the eyes didnt seem to as smooth as other rods i've owened. When i Fished Jozini, i had to keep dipping my rod tip in the water to get the smooth for the next 2 casts. what the hell?
I got some advice to clean my eyes with diamond guard and to put new line on. I did this, but when i fished yesterday, it still felt rough and sticky.... not cool...
So I swopped this rod for a 7"1 G-loomis mossy back. I went for a stronger rod since my 6"6 didnt feel comfortable throwing heavy lures. (probably because they were too heavy).
So now, I have a much stronger rod, and im worried im going to damage or wear out my stella 1000. In the sense where the line pulls up against the bail, could it cause damage to the bail/reel if too much pressure is exerted on it?
Let's say the spool says 6lb-150yds 10lb-120yds 12lb-80yds. Is that also an idication as to what the maximum line strength the reel man have exerted on it?
Sorry for long explantion. just want to hear some opinions.
JasonG
I also e-mailed shimano, and thier quick responce is awesome. They say the maximum drag you'l get out of the reel is 5kg. and that is what would save the reel from being over worked regardless if line/rod strength.
Fin-S
Remember that the rule of thumb is to set the drag at between 25% and 33% of the lines breaking strength. On my small gear I will always have at least 150m of line (personal choice). On your reel then, 150m = 160 yards, which they reckon is about 6lbs. Then I would set the drag at 2lbs. This should not damage any reel - even if you were to buy an Okuma!!
