Reel options help please.
drewpollard
Hi all,
My father has recently had a handful of his reels stolen, so we have been looking at getting something in the meantime for surf and rock fishing from the beaches near our his home.
I have been looking at the Shimano Torium range, as what I have read on the forum has pointed me to these. However, I cant seem to figure out which model is suitable? If someone could please give some insight into which would be best, I would appreciate it. Also, I have read that the toriums arent actually made for surf casting, but only us South Africans use it for that. IF thats the case, are there not better options in that price range?
Thanks in advance,
Drew
surfboy
Depends what you are targeting. I fish for edibles (Cob, Steenbras, Elf, Das and Galjoen) and go reasonably light off the surf and lighter off reef. I have a Trini 14, Torium 14 & 20, Daiwa SL20, Daiwa X30. I find I fish the Trini 14 and Torium 14 mostly and will be starting to use the SL20 for scratching. My rods are 10' to 13'. I have kept the Torium 20 as a spare heavy reel, in the event I feel I want to specifically target cracker, and of course one does not recoup the reel's value selling a second hand reels. I find the Torium 14 a great reel, compact, smooth, easy to cast, easy to service, great balance on a 10 - 13 foot rod. Has centrifugal break blocks for those who like. I use 0.36 mono with 0.55 shock leader. There is enough line on there for most fish.....still need to test line capacity on a really big steamer. The only upgrade I would seriously recommend is to put in Carbontex drag washers. I have just recently put on mine, and my confidence levels in the reel shot up 20 percent. I'm not necessarily punting the Torium as there are allot of other great reels out there.....just takes time and money to try them all out. For the time being I'm happy with my setup.
i want fish
hi the torium reels are very good solid reel and they cast fine,if you like you could magg a torium 20(good sized torium for any and all eds) and then cast a mile and have a very durable reel,otherwise you can get great casting reels out the box like the daiwa saltist 30 or 40 or the penn fathom 25n or 30 both also amazing reels and around the same prise,cant go wrong with either of them,if you looking to spend less money but still want a great reel that will last for ever and casts great get a sl30 or 50. you can also get a shimano speedmaster or tld 20/40 or 15/30 very affordable but dont cast as well as the daiwa sl range and the tlds are a bit slow for my liking but indestructible.
drewpollard
Thanks for the responses guys! I'm now leaning towards the torium 20. The 14 sounds great but I think the 20 will cover for both the smaller and bigger edibles. But I will look into the sl's etc.
Cheers!
