Recipes for carp ground bait
G
Guest
Guest
At present I am using Supercast "popcorn" but would like to experiment with "heavier" ground baits.  Any recipes for mixing a ground bait that can stand up to a bit of a current?
Naruto
Oops! Wrong section.
Anyway, try The Original's fine groundbait and mix in some maize-rice to make it heavier.
Welcome to sealine!
G
Guest
Guest
Thanks for the tip.  Will give it a try.  Must just find a tackle shop here in Cape Town that stocks "The Original"  Failing this, do you have any other ideas for groundbaits that I can try here in Cape Town.
Naruto
Any fine groundbait should work. Or you can string a baitball/molassesball onto your leader above the trace. Should hold up long enough. Look in the specimen section for topics on how to make these balls yourself.
G
Guest
Guest
Thank for the advice.  Going fishing on Friday and am keen to try the molasses.  Had a lot of rain here in the Cape and the large amount of fresh water means that the fish love a bit of salt.
Will let you know how it goes.
Thanks again.
zimbo
You could also use Chicken Feed like Layers Mesh, mix it with bread crum so that it Binds together well add a few free offering of Sweet corn to your mix. and that should really pull in the Carp! best method to use this mix is using the Cage Feeder! with the corn used as your hook bait! have at least 6" of hook length attached away from your feeder!
G
Guest
Guest
Hi Zimbo
Thanks for that - but should I cook the chicken feed first?
pappi choulo
uncooked chicken feed can kill fish! if u soak some chicken feed in water you will notice it swells...now imagine a carp feeds on uncooked feed until he's full and the feed starts swelling in his gut...where do you think its gonna go?
big one
hey an even beter way is to soak hole mielie pips for a day and to then cook them untill soft and nice big... then but then trough a mincer...:fishn i have caugth plenty of carp like this and it's leka heavy:wfish
