Quarry Baber!
errant
Hey guys! Just returned from something really fun, I am going to classify it as Baber cliff fishing!
One of the quarry's in Standerton is said to hold more than a ton of Baber, the smaller quarry before the large one holds bass which for the first time I managed to pass without stopping for the bass and becoming distracted!
We weren't carrying any live bait so we tried plastic horney toads, Craws and a few others with no luck what so ever, slow retrieve fast retrieve, klopping.... nothing worked. The baber where turning on the surface teasing the hell out of us.
About an hour later a fellow angler arrived with a Plat Anna dangling from his hook, he had just found it in his girlfriends swimming pool and dashed over to the quarry with mass excitement! So we stood by as the platti swooped down the 10m cliff drop in search of its prey! As the platti hit the water a large whiskers came up and engulfed the little amphibian a few seconds fight and the frog let go of the baber, miss! Next throw the Platti swoops down again and takes hold of a rather large whiskers... bang snap goes the line and the platti is never to be seen again!
So what now, mass excitement! The search for a crab or two begins! Its live bait they want! So three crabs found and in no time we are flinging these little crustacean dive bombers into the quarry! Third cast, bam, Fish on, then fish off and crab gone..... well thats me! The other two loose their crabs shortly after that and mission failed and we retreat for the night!
Sunday arrives and I am sitting in the lounge pondering, I call an 1 hour session at the quarry, have to figure these guys out! So I figure they want something that looks like live bait, so on goes a swimbait kurper and well nothing after many a throw...... I was about to give up when I looked in the tackle box and saw a double bladed efzett, on she went and over the cliff, I thought I would klop with it and boy was I in the right direction. Three or four klops and first fish on and this time she wasn't coming off! What an awesome fight from a cliff ledge, must be one of the most interesting styles of fishing I have ever had! Eventually the baber tired, wasn't too big maybe 4-5kg so I thought let me reel the bugger up the cliff lol and up she came must have been a first time experience for a baber to fly.
With the first baber retrieved and then released I had to prove to myself this was not a fluke and cast the Efzett with the same approach, three klops later and bang on like donkey kong, This time bigger, what a fight, eventually after many runs the fish was tired and now how do I get her out to de-hook! Hmmm there is a section of rock to clamber down a few meters away, so fighting the fish whilst balancing on a cliff edge I moved to the rock face and clambered down, retrieved the fish and released! ? Unfortunately I had to call it a day but will return with my new secret weapon for the really big buggers lying in wait!
One thing confirmed, the right lure used in the right way is possibly as if not more deadly than live bait!
Basspro
Let me ask a question: I have some lures, I want to try this klop approach from the inflatable or the bank .... how far must the lure be from the the point of the rod & what rod length is best for this ?
errant
shuraj wrote:
Good luck , make sure you have the right equipment for that once in a life time fish.:wfish
I have made the mistake before, not going to let that one happen again! Lost a LM of my dreams lat time!
errant
I was "Calling" from 10 meters above the water, so the length of line seems not to be an issue. I think the technique is more important. I let the lure plop into the water letting it sink a few seconds and then give three solid jerks of the lure till it arrives near the service, let it drop to the same depth and then three more jerks, following the same process had takes within 2 minutes on both occasions.
I think the trick is to locate the depth at which the cats are and then giving the lure enough motion to create noise but not taking it out of the relative area or the babers will not be able to locate the constantly moving lure.
kitefisher
Hi Errant
Always great to explore new tactics, nice catches. I feel what you need there is a nice sturdy rod with maybe 50-60lbs braid on,you dont even need much,maybe 80meters or so. I am not sure if you tried casting the EFFZET,but believe me many many cats have fallen prey to a slow retrieved EFFZET spoon,The double blade one works when the fish need a bit of noise to generate a strike ,but you will find sometimes they prefer the quiter single blade ones. They can be caught on the smallest of small EFFZET,'s those tiny ones as big as a grown mans thumbnail,search around you get them at tackle-shops.If all else fails ,places like Makro or Game also sells a look-alike of the EFFZET,just remember that their splitrings and hooks are not up to scratch.
Cats can be caught on other spoons as well,as long as they have a very wide wobble(side2side action) and dont need too much speed to stay at your required depth. Obviously your method works well,and it gives one some sense of satisfaction when you sort of ''crack the code'' to a specific water-mass.Well done again.:wfish
Check out the spoon in this pic,the very same spoon has accounted for a good couple of shad.
errant
I am starting to learn that it is the most simple lures that seem to work across the various fishing disciplines.
I was using 21Kg hi abrasion mono on a small stiff boat rod with a Shimano ST10000 baitrunner, maybe I should upgrade the line just in case!
Can't wait to get back there! Would you say a bigger lure would attract a bigger barbel? I think the second layer of ledges should hold some seriously massive fish! I am finding quarry fishing very challenging but extremely rewarding.
kitefisher
Errant
The biggest advantage that braid would give is probably in the diameter.Your 50lbs Mono is pretty strong enough to catch your monsters especially given the terrain,but 50-60lbs braid would arguably give you a diameter of.30-.35mm (depending on type,you dont really want the super-thin superlines).
The latter diameter would be more user friendly in the casting dept,as compared to your mono which in the strength that you mention should mic about .55mm.Not impossible to cast a light lure with that on a grinder,but you'll soon notice the difference.If you dont want to lose the mono,see if you cant just add the braid on top of your existing mono on the reel,just make sure you have enough on so the braid is always on your reel whilst fighting the Cat (one less knot to worry about).Maybe you need only 50 meters for that specific water body.
As for lures,plenty guys on here will give you loads of info regarding lure size,and some spade work has been done in that dept.I would guess that the bottom line still remains that some huge Cats have been caught on fairly small lures.Give them the size that they want to eat on that day, and at that water-body,it aint always gonna be the same one trust me.It may be seasonal or it may be that the isze of the ones that are feeding predominantly right now favours the EFFZET,keep on giving it to them until they stop wanting it,only then experiment.
p.s Try and tie that little red thingamagic of the EFFZET onto another lure and see if it changes the strike-rate,many old hands used to tie red wool onto there trebles back in the day,(lol,sound like an old toppie),but nonetheless,it was believed to work great even for shad.
Enjoy and post your weekend pics:wfish
errant
I use braid when fishing for tigers and find it nice and responsive can get that hook set with min stretch or "lag" I have some really nice mono, I love my awa shima lines and its a 21kg 0.38 ;) like all the tips, I am starting to pick up the little red tag plays a rather important role!
Bigdan
Well thanks for the info, I regularly visit the inlaws in Standerton will go and look up this quarry that you talk off.
maybe we will meet at the water.
errant
Will be in Standerton easter weekend, pm me and let me know when you going to St anderton, got some good spots at the dam :)
