purglass 300/4
slater
Hi guys,
I am about to buy this rod and need some info. I intend to use it for bigger eds and ineds. I would like to be able to slide - so it must be able to throw a 7 ounce sinker with the heavy tip (its 3 piece).
I know its 13 foot - i'm not tall so i feel more comfortable with a 13 foot rod.
thanks
Slater
300/4 is a 10' rod. A 350/4 is the 13' and a 400/4 is 14'
It's not quite the rod for ineds but it will get the job done. You would rather look at a /5, I just got a stronger backbone and a 350/6 would be even better.
slater
Enigma,
Thanks you must be right its the 350/4. Is this rod not suitable for ineds and if so is the /5 not suitable for eds...
Also is this the best rod for my application?
thanks
Slater
ter if you are looking for a rod to occasionally catch in-eds with then the /4 will do fine.
I just built myself a 400/5 3 piece for a trip to Namibia, they didn't have /6 in stock and I'll be getting 3 of those machine blanks in 2 weeks time.  The reason I used a 400 is that I cut it back on the butt to allow me a 13' rod with 3 x equal length sections.  I'll post some pic's when I'm back next week.
With the /5 I can cast from a 4oz (long drop) to a 10oz although it is most comfortable with a 7-9oz
The /4 is a good rod and will pull hard on a big fish.  Noweeds caught his SA records Bronzie of 227kg on a /3 but then again he aint no ordinary fisherman like us mortals.
If you're buying new then I would recommend a /5 for your area but if you can get a deal on a /4 then it will do a good job, if I had to equate it to anything on the market (commercially available) then it's a lot like the 6-8oz Shimano Exage.
Firoze
I have the 350/4. Very light and casts very well. It is great for lrger eds and ineds.
I was told once "Give the fish the Competitive Advantage" by an old man. The /4 casts most comfortable with an 8 ounce although it is rated as unlimited according to Purglas.
