PUMPKINSEED CASTING ROD
Droomvanger took a concept rod along to the Bloemhof Bonanza for specific use as a casting rod for his Lume Pumkinseeds.
He needed a rod that could cast a lure to turning catfish but had enough backbone to lift a big cat off the bottom and then at the same time be short enough for use off of a boat for Artlure.
The basis of the rod is an top 7kg PE5 6'3" Jigging rod. Rebuilt to a casting rod that can be safely fished with a Calcutta loaded with 65lbs braid.
(Bernard, please post a pic of the fish you landed with the concept rod) No ways these cats were going to hug the bottom when hooked on this rod.
The Owner
Hi Enigma, the rod looks great! Here's my dad's cat he caught on your concept rod
Skuimkop
Flip daai is nou 'n mooi rod. Hy sal ook vreeslik lekker werk by riviere as jy by die oewer op of afloop met kunsaas en babers soek wat draai.
Enigma what would these rods go for? I might  look at one when I go to the Orange river again in the future.
This is based on a very high quality, 7kg drag rated jigging blank so you're looking at around R1300 for the rod
There are other models however and you can also play with components to vay prices to keep it under R1000
The popping rods in the following post will do well as bait fishing, pumpkinseed, river and boat fishing, at 8'
http://www.sealine.co.za/view_topic.php?id=73441&forum_id=1
