Prawn Dropshot
Big G
Going to throw net for swimming prawn this weekend. Then later I will drift a bait out in the river and while waiting will do some dropshotting from the bank. Planning on using a live prawn on my dropshot rig instead of the usual Berkley plastics. Should work. What do you think?
Nepptune
G - Can definetly work mate, and I have used this method plenty in the past.... One can fish all sorts of live baits off a lead head, inlcuding Mullet, Sprats, Anchovies, or whatever is on hand....
Try experimenting with differnt hookup style on the prawns till you find one that works best....
Usually hook through the head from the front for fishing slow crawling action over sand banks.
If you want to fish a little quicker "hopping" action, then hook from the tail side so that the prawn hops backwards in retreat when retrieved.
Also, if you are fishing with bucktail/Leadhead jigs, tipping them with a natural bait can always improve your chances... you can use Chokka, Prawn, or a strip of any bait fish you have on hand...
Big G
Will try a few different hookups on the prawns with the lead jigs. Head to tail and vice versa.
Also going to try a bass carolina rig, using a bullet sinker for weight and fluro leader with circle hook. Attach hook through 2nd last segement of tail. This should give great movement in the water as the prawn will be alive.
Good to mix it up when fishing.
