Powder coating lures etc
Ryan
Maybe this is a question that needs to be posed to people like team leadhead.
I am wanting to powder coat tungsten beads into seriously loud bright colours.
Is it an easy process?
Where can I source powder paint in SA?
Are there any tricks in getting a nice solid coat?
Is there any special equipment required?
Anywebsites I could visit for further advice?
Thanks all
Hooked
Thanks all
Dont know much about powder coating but if you want a coating to be properly done take it to some where that does industrial sand blasting.They normally have plural spray equipment .
Hooked
Seems the best way is cathodic cataphoretic paint deposition.I know of a plant in EL that can carbon vapour metal deposition , I will give tham a call tommorow
munga
Thanks all
Hi Ryan
Powder painting is super easy. You can powder paint a batch of 20 leadheads in under 10 minutes. We buy our powder paint online from the US on sites such as cabelas. See link below. Pro-Tec is a good brand.
The trick to getting a solid coat is heating the lure to the right heat before dipping it in the powder. I dont use a spray gun. I simply heat the lure and swish it and swirl it quickly through the powder. This will ensure an even solid coat. The only downside of powder painting is that the paint chips after fishing around structure for a while. This can be avioded by oven curing the lures which is a longer process and i wasnt willing to get lead poisoning from my roast chicken!
I have attached a link below which will provide you with advice and any equipment you may need to coat your beads.
http://www.luremaking.com/howto/powderpainting.htm
http://www.cabelas.com/cabelas/en/templates/links/link.jsp?id=0036460318842a&type=product&cmCat=SEARCH_all&returnPage=search-results1.jsp&Ntk=Products&QueryText=powder+paint&sort=all&Go.y=4&_D%3AhasJS=+&N=0&Nty=1&hasJS=true&Go.x=22&_DARGS=%2Fcabelas%2Fen%2Fcommon%2Fsearch%2Fsearch-box.jsp.form23&_dyncharset=ISO-8859-1
Munga
Dingleberry
Howzit. Another thing or two. Cabelas wouldn't post powder paint by air. It's obviously still classified as a paint (flammable). Do-It molds would post it by air. The fluid bed is an absolute must and is obtainable from Do-It. All it is is an aerator pump linked to a cylinder with a cup that contains the powder to be fitted inside the cylinder. The bottom of the cup is filled by an aerator stone. The air from the pump passes through the stone and the powder in the cup and fluffs it up. One can actually swirl the powder around in the cup like liquid. Wih the use of forceps, a heat gun and the fluid bed, one could probably paint a hundred jig heads an hour.
