Poppers
Flippie
I have been playing with surfboard foam to make myself a popper or 2
1 for leeries and one for bass
Here is a pick of them.
Input would be great i havnt done paint yet cuz i dont know what to use either than resin and some coulor.
POSTHUD
Looking good..
If you do not have any means of painting the poppers, you can buy rattle can spray paint and spray them. You can get some nice effects with this, but unfortunately, cannot do detailed jobs.
With the surfboard foam, I would suggest sealing it with epoxy/resin first and then painting as it is quite soft. I used to do this when making saltwater poppers for fly-fishing.
Here are some effects you can get with a normal rattle can spray paint.
Silver base coat, metallic blue back, and then pull a net over it for scaling effects..
POSTHUD
Another one,
White base coat, then yellow on the top half, then orange back.
POSTHUD
And last one,
White base coat, blue top half, and purple back.
Hi,
You will have to seal it with resin. Just bear in mind, it's going to get destroyed in no time. I have made lures this way in the past and even tried fiberglassing over them to try and make them last. The other option is to seal it and get it as smooth as possible with layers of paint then make an RTV mould to reproduce it with a PU resin like feather light.
Flippie
Thanks for the input I dont worry if they get destroyed cuz they are easy to make just the paint would take the longest
Im gonna keep the first lot white and see how they work and would later work and play around with paint.
Whill post picks ass i progress.
