Poeier Os bloed
Mariner
Ek het poeier os bloed gekoop om babers te vang maar weet nie presies hoe die goed gebruik word nie. I daar iemand wat my kan help.
nobbles
If the ox blood is just a dip, than use as conventional carp method. But if your using real blood, wich will work better I'd soak the bomb in it. This will give the bomb a slower realse of the blood and create a nice constant scent trial to the earth worms. Try mixing the blood with the water and mess around with ratios till you find the right constancy for the bomb
