Please help me make my final decision
What spinning reel would you buy?
  • Fin-Nor Lethal 60/80 (R1250)
    Votes: 0 0.0%
  • Okuma Azores Z-65S/Z-80S (R999-R1099)
    Votes: 0 0.0%
  • Okuma Trio Rex Salt 60 (R1667)
    Votes: 0 0.0%
  • Penn Fierce ll 6000/8000 (R1270-R1400)
    Votes: 0 0.0%
  • Shimano Exage FC 6000 (R1590)
    Votes: 0 0.0%
  • Total voters
    0
JeandlH
If you had to choose between these reels, which one would you get? And why should I maybe avoid some of the reels. And any other suggestions would be appreciated.
1. Will be fishing for edibles only, mainly in the surf with bait and sinker.
2. Going to load it with 30 lbs braid.
3. Still deciding between a 12ft and 13ft rod, both rated for 4-6 oz.
4. Really tight budget of R1800 Max for the reel.
Arno Nel
The trio rex salt is a casting reel and you wil get better distance with this than the others. You should be able to load +/-500m of braid onto it.
You might want to consider 25lb 8 strand hmp braid. Enigma has posted somewhere on the forum a note of how much braid you will be able to fit on this reel
Lethal 60, in that budget..You need to spend a whole lot more these days for a shimmy with the features you want. For all round fishing the gear ratio is fine, would like bit faster for plugs but it works, just fine for lifting a sinker out of foul terrain and nice for fighting bigger fish. Strong gears in that lethal, not just hype. I'm a shimano fan but in that price that finnor beats most/all reels twice its price.
http://www.tackledirect.com/fin-nor-lethal-spinning-reels.html#tab3
Was reading the reviews on tackle direct, they don't sound like shills and sound like legit reviews. And they are glowing. I had one of the first to come out and it still fishes like it was new three seasons in. Not even a line roller bearing replacement yet.. It had an issue almost out of the box with the drag knob, quality control, but the international guys sorted me out within a week when I gave up with local agents. Great reel, solid gearing meant to last. Mine does not get used that often now that I'm scratching around with a saltist40 and mono to learn the ropes..but that reel has caught me a few different pelagics, been to sea many times in the spray an all, fallen in the shorebreak and become one with the sand (and serviced right after!), caught my biggest cracker to date of abouts 14kg and he came in skipping on top of the water when I put the brakes on him and cranked, caught many ray and small sharks like gullies etc..It fishes like new, just smoother like its now run in. Drag I can't fault. Toughness and longevity of paintjob is top notch. They really tried to shake up the market with this reel and there isn't a match yet at the price..The 60 is right size for scratching, maybe 80 for more line capacity but the reel is larger and heavier, you must see what will balance your gear. The 60 is the same as the shimano 8000/10000 size.
I just don't know the okumas to give you reel input, there has in the past been some concern about the gears and I think the jury is still out in their lower ranged stuff, but I hear great things about their new top range stuff, the fin nor's gearing seems to be really tough, mines' look new still when I service it. I'm just really stoked I got my lethal when I did, good investment seeing as the price was sub a grand then and I am really happy with it generally and not as a budget reel. Had a finnor rampage prior which was a cheapo P.O.S. but I reckon the makers vindicated themselves with their lethal spinner.
I don't know how many times I've repeating this on here though..if you search you'd pick them up for sure, can you look and feel the reels and review them? Or post up once you have your choice in hand and fished it a bit..
JeandlH
Okay, I think I've made my decision. I'm going with the Fin-Nor Lethal 60 loaded with some 25-30lbs braid. And I'll do my best to write a short review once I've used it extensively.
I'm also thinking of getting the Lethal 100 somewhere in the future for some inedible fishing. There's alot of guys using this reel for inedibles in SA, and nobody can believe how the reel performs in comparison to reels double, or even triple the price.
