Pentagon Grinder P6
Surfmate
I have been reading about these Pentagon P6 Grinder rods from Gremlins in Margate.I`m Presently using an old generation Assassin Medium Graphite that I`ve set up to use with a grinder (the Shimano Ultegra 14000).Must say I am enjoying the fishing with this setup.I am getting better distance than with a multiplier,but not massively so, however the advantages of fishing with braid have been well documented on this site .
My Questions are:Would it be worthwhile investing R3000 odd on the new generation rod from Gremlins ? Will the performance be significantly better than the current set up I have?
Any input from someone who has upgraded to the P6 from Gremlins would be much appreciated.
scorpion
I am looking for something along the same lines. I spoke to gremlins and the way the build the rod. Very interesting as the rod can be used with a conventional and grinder reel.
I also spoke to enigma from cds and his version of a grinder build was very different and more focused for the ultegra as the guide configuration will be set up specifically fuji k frames. Lots of advantages in terms distance and line management and distance.
Also enigma will test cast the configuaration to make sure it meets the needs of the angler. We in the cape also contend with strong winds, so that would be another factor. I am not comfortable throwing a grinder with the reel mounted low on the butt.
I am sure this can be overcome with use, as the bionic finger will allow heavier weights to be thrown with more confidence. Another option that will be avaiible shortly is the waft iron feather and pirate series of rods.
 I would like to test cast a p6 in the low reel mount configuration just to check how i get on with it. I am looking to target edibles at distance with the set up. Are you looking att edibles or small to medium sharks etc.
 Your feedback will be appreciated, two heads are better than one. Some awesome technology avaiblle to us.
(Edit: ADMIN S)
Surfmate
Looking at using the setup in competition angling,mainly for edibles ,but need it to handle sharks and flat fish when necessary. I have a customised Blue Marlin 7+1  to throw heavy baits for the big fish so the grinder outfit will be my other setup.
I have got used to having the reel mounted low and it is not a problem for me.Would like to get some input from Enigma (after reading what you say) before I make a call on the Gremlins rod.One of my concerns is that their rod is a little short for me.It is 13ft 7 in compared to the 14ft 6in I usually use.I have a 13ft 7 in Pentagon  that I bought from them and actually prefer a Loomis Shockwave HMG to this rod .This is my opinion only and not knocking the Gremlins product in any way as many top anglers only use their product .
Bionic finger is a must for me.
How did you get hold of Enigma?
Will keep you posted.
scorpion
The whole point about the using a grinder set up is to get distance using a liter sinker than u normally would using a conventional reel. So i willl set up the rod specifically for a grinder, using fuji k frames. Takes care of windknots and when set up correctly, distance. The length of the rod can increased with butting, no biggie. Cds tel no. 012 335 8144, tel him Reza referred you. There are purglass slimline blanks as well and fuji lowriders are another option. Craig will sort you out. Which ever way you go make sure the guides are set up specifically for the reel, spool size is critical. I am still on the fence about using a grinder mounted low. Keep well and keep us posted.
Carll
Hi Guys
Im also send Enigma a pm and want to find out about his spinning rods,is that his tel no ?scorpion wrote:
scorpion
That is his number, also guys give Robbie Janse a call about the waft rods coming in. There are plenty of options out including the daiwa saltiga rods as well. Keep well guys and post feedback.
The Gremlins team have really good rods nd researched and tested all the rods.
Long rods smaller baits, shorter rods bigger weights and stronger pulling.
13' is probably the best all round length for heaving weights to the horizon and still be able to pull the jaw skew of any big fish
I personally prefer 4m setups and with the right 13' HMG 200m with a Grinder is no problem at all.
The Assassin you have and the P6 will be a much of a muchness so you'll probably just be duplicating in getting the P6
I personally prefer a low seat for casting larger weights ie 6oz + bait and for Plugging
Bait fishing with 3-5oz I would use a long butt (do use) as with experience you use the butt as a lever against your body and when using a 13' rod with a long but you can effectively shorten it to 11' when playing the fish and have better control over the rod
If building for targeting shark (any size - rememebr a bait on a steel wire can hook you up with 10-200kg of muscle) Then take the low reel seat for purposes of using the bucket and pulling
Don't go for the shortened long butt because you won't get enough leverage to cast a big weight.
