Hi can any 1 help me with some pictures or a link on how to assemble a Penn 49.
It is my fathers and I striped it to clean the inside but nw I can't get it back togethere. If there is any 1 that can help me in anyway it will be appreciated
Hi Sylvester tanx very much that was very helpuful is its just the dog and the dog spring that is very confusing. I put it together but the eccentric lever(Drag lever) does not work it has something to do with the dog and dog spring.
I finally got those pics of the opened up Pen49 i told u about. I hope they are of use to you. The reel doesn't look to good anymore, but you can see it's been used alot.
I hope this helps.
llcoolj, you still need the manual? I found the PENN 49 Schematic and Parts list. It basically tells you where every single part goes and how to assemble...Let me know I can email you. Will also post it under Reel Servicing, if you need it...
Why do you want to replace that parts mentioned in the PM ?
Mail me some photos then I can see if its really necessary to replace them ?
I have a parcel I need to send with a lift to Henties. If we can sort out the parts problem before then . I may be able to help you with some parts on the same trip .
